Originally posted by tombraga View Post
agree totally, please users, don´t make any confusion!
Until now the update filosophy of SC was great and should not be alterated now.
Please make the SCV7 also with the same ota zip file, thanks a lot.
So if I want to try SCV6, I have to start with SCV4, then do 3x OTA updates? - YES
So why is there no SCV6.IMG image file so we can just jump right to SCV6 (or SCV7 when it comes out), without all those other updates?
I mean, if I were to have just bought a Box and wanted to try SC's LATEST ROM (SCV6?) - I could NOT do it in just one step with USB Burning tool if I wanted to.
And considering how many people are having issues performing OTA and are STUCK on SCV4 not being able to use OTA for SCV4a,4b,5,6,etc. - having SCV6 as an IMG file seems like a No-Brainer solution.
How is this wrong to request this format, in addition to the OTA formats we've been getting? (NOT "INSTEAD OF" as some people have mis-interpretted my writing). - He already has it on his computer, and it would only entail a little more compiling of code.
Wyle
You don't need 3 x OTA updates. If you are on stock ROM, first you need to update with SCV4 and then straight away with SVC6. I would suggest to update SVC6 from TWRP.
SVC4 is only required if you are on stock, once done you can jump to any custom ROM. I think it is clear enough in the first post from Superceleron.
chenrp
Just like me, there are lots of people having issue with reboot and reboot to recovery. I have found that it is due to sh*t power supply came with the box. Last night I had powered the box using USB OTG cable and 2A mobile charger and reboot & reboot to recovery worked.
If you are using Wetek WebOs Launcher, here are the comments from the first posts.
- Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- Long press on the default icons on desktop you can change them to other apps (White Logos...)
- Long press on the icons you add to the desktop and you can rearrange them.
I am not sure about Youtube but I think it is Android TV app and mouse don't work with it.
Originally posted by chenrp View Postdamn... my box won't power up with power adapter... when connected to usb it boots little after the boot logo. not enough current i guess. and i guess that the power adapter is poor quality
At last.... Everything looks great...Thanks a lot super Celeron for your great great work!!! The only problem I faced was the drivers. I never made to connect pc with the box (no drivers, I opened the box and I try the other 2 ports but nothing happened) but I did with the SD card. Then recovery and everything is perfect. Xposed,adaway,magisc. Thanks really for everything!!!!!!
Στάλθηκε από το ONEPLUS A3003 μου χρησιμοποιώντας Tapatalk
Apples magic mouse is not working with any rom i tried but its working in my phone so i checked and myphone have module named hid_apple and hid_magicmouse in /sys/module folder. i tried to copy it but is not pasting on box through total commander or twrp recovery file manager. Can anybody help?
There are currently 1995 users online. 1 members and 1994 guests.
