maybe you can try to reflash your box with SCV4.img
Originally posted by valencia7514 View Posti think my power adaptor get broken, it wont boot the box
is it safe if i use 5v 4A power adaptor since the adaptor came with the box only have 5v 2.5A?
Originally posted by Bobo357 View PostWhat this mean?moved the box.The ota flash from twrp is 100%ok.I test the scv 4 scv6 finaly scv 7 in all rom wi fi is pure,in stock rom I tested the last 3 new stock rom and wi fi is full and stabile.
Poslano sa mog Mi-4c koristeći TapatalkYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
yes it can. just power up the box and press the reset button. hold the reset button until the box enter recovery
very easy
Originally posted by Wyle View Post
APPARENTLY NOT - You still aren't actually understanding what I wrote. I feel as if I'm being replied to by a broken tape-recorder (AI?). You keep repeating what you already said before.. when I have explicitly written that the box won't do what you are instructing me to do.
I'll chalk it up to poor translation or bad reading skills.
You keep telling me to reboot box and press pin in.,. when I'm writing you that the procedure doesn't work on this box - it gets stuck on boot screen and won't go into this "mode".
But thanks anyway.
Maybe we (actually you - Wyle) should take a step or two back...?
You quoted one part of ReaperMan's quote, but missed the most important bit...
Originally posted by ReaperMan View Post
P.S. We can't see what your doing over there..so we try to offer the best help we can with little info.
For example - I have H96 Pro+ (not Alfawise) 3GB (DDR3) / 32GB (can't remember EMMC manufacturer right now), bought it in beginning of May this year from B....ood. And I can flash SC ROM's easily, I can reboot to Recovery on stock and on SC ROM and I even have dual boot from SDCard to LibreELEC runnig just fine...
Like ReaperMan said - you can list ALL the steps that you have done... one by one... do not skip any detail
Once you have all your info for your box, I might suggest trying to flash stock ROM back to the box. This will revert the recovery from TWRP to stock one.
Can you enter the recovery on stock?
And you can even try doing the LibreELEC dual-boot thing - just look at LibreELEC forum for instructions. You can do this both on stock and on SCV4.
This includes the toothpick method - maybe this will work... And if you are able to dual-boot to LibreELEC, you can even try rebooting to recovery from there - I have no idea if this will even work from SDCard LibreELEC...
And you can even try adding more power to the box - replace the power adapter for higher Amps one...
I do not know if adding additional USB power-cable would help... But you can try powering it on using USB power...
Like I said - adding my two cents to this issue... Just because the issue seems so curios to me - it might very well be, that they (the "hundreds of manufacturers out there") have changed something in the boxes to prevent booting to recovery... Or it is just this SC ROM, that is causing the issue (try older SC versions - the one's not based on Nougat)...
Originally posted by chenrp View Post
the 2.5a is sufficient.. but the adapter fails... here are the capacitors in the adapter that failed:
i meant that maybe you moved the box and something is interfering with the wifi..
is it the one with 1000uf 10v or the black one with R5M1 written on it?
i found 5v 1.5A power adapter in my drawer, and the box running againLast edited by valencia7514; 11 October 2017, 11:14.
i'am sorry i dont get it
good to hear that your box is running again.
Originally posted by ReaperMan@ nibble,
If box is buzzing and new, can you return to vendor...faulty box?. Did you buy with Paypal or pay extra for insurance(Gearbest)
A good video with audio sent to Paypal will probably be reason for money back or replacement.
Consider before opening...if return cost warrants a return or free replacement
Enviado do meu SM-G950F através de Tapatalk
Originally posted by valencia7514 View Postdeviltheturtle try this rom
flash it with usb burning tool
msc1 seem to have same hardware like yours and got it working
@superceleron
one person flashed the TANIX T8 MAX rom on the h96 pro plus, and says that the device runs cooler...
maybe it is worth reviewing...?
update :
Please do let us know how it works. Pretty sure more fixes in this one but carry on.
Yes i know about for more than 2 months now.. but to many inconvenient on that one...
Btw i do have internal access to tanix( in this case the factory behind tanix and many other brands) sdk... i just cant share it, not even compiled!
Ok starting to delete posts and watch bit more here. Some just dont get it so let me explain.
Developer fixed a ton of issues. Provided updates provided ota. If it doesnt work on your device maybe something changed. We (Moderators) have tested and retested and IT WORKS.
Maybe post a dmeg or error your getting. But Developer cant solve every box thats cloned. I think he done fantastic job as I know of 6 devices that also work on this that I have tested.
Cant flash the Ota..... Oh well flash stock if its that important. Pretty sure few minor ota things wont stop you from using the box better then any stock firmware.
Lastly. Be very very polite to all of our developers as they do this for fun. If you have a question first READ the thread lots of useful posts.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by PugnettaVery good work rom very stable and fluid but I find it very annoying the status bar to disappear would be much better as it is in the original manually ruined rom stock, I use Apex launcher and the bar goes to cover the icons of the last row down . So I was wondering if it was possible Superceleron when you have a little time to create a ZIP unzip download ZIP download package. I have two ZIP files for flashing:
the status bar auto hide..zip
the status bar without disappearing..zip
Thank you ..
superceleron may i know why led control from navigation bar feature was removed i think it's was a great one because blue led is very distracting especially when tv-box is near TV
There are currently 3582 users online. 1 members and 3581 guests.
