Originally posted by valencia7514 View Posti think my power adapter 5v 1.5A is not enough, everytime i plug in my hdd external (touro 2tb), the screen goes blank and no signal and i have to restart the box
Originally posted by nibble View Postsorry, if I'm one more to ask, or if was written many times:
But, how to update OTA versions?
1. format a 4gb or higher micro sd card
2, copy the img you want to flash to the micro sd card and eject the card from your computer
3. power down your H96 box after making sure it does power up first before starting
4. remove the power cord from your h96 box and put the micro sd card in it
5. use a toothpick or paperclip and depress the reset button and keep it depresssed while connecting the power cable
6. watch your tv for the TWRP to show on it and release the reset button and follow the instructions to find the sd card img and load the firmware by sliding the execute switch
7. NOTE: you will need an air mouse or wireless keyboard to operate the switches on TWRP
8. Reboot when completed, but note your box probably will just shut down and you will have to power up manually (don't ask me why because I don't know why)
Originally posted by neutester View PostDid it boot up ok after you loaded SVC4? Did you get any errors when flashing SVC7a? If it SVC4 booted ok, then check to be sure the MD5 is correct on the SVC7a and then I would reformat the microsd and recopy SVC7a, and see if it does the same thing.
Update 2: It booted! Thank you mate for help and suggestions!
Originally posted by ReaperMan View Post
Originally posted by tombraga View Post
valencia7514 you saved my 3. box Alfawise, thanks a lot.
As i reported already here, my 3. box i bought (the cheap one) only gave me headache, until yesterday. I already contacted Gearbest to plan to send it back.
Short review: the box arrived and i had in plan already to update to SC rom as my other 2 boxes are working fine with. So i even don´t remember more which 7.1.2 stock rom was there (which date), i only remember, that changing to Nova Launcher was not possible, always message, app was closed.
first i could do the update to SCV4, but with problems, screen freezing during update, then with problems udpdating to SCV6, but the box never worked, display away, rebooting, crashes a.s.o.
For me was clear, this box has a serious hardware problem. It got hot, but not so hot, maximimum 62-65 º, but mostly 58-61.
So i was so frustrated, i tried to install all versions from superceleron again, from begining to end including ATV roms. Also tried to install the the stock versions i had from Alfawise, always crashing and screen problems.
So yesterday i tried the last time this rom from valencia7514 and voilá: i could install (ok with sd-card) it and now i changed to TVLauncher and it is working so fine. Thanks coni vigo for the info, i agree with you, this launcher is simple and working fine.
I am happy now that my 3.box is working now, but at the same time, very unsecure what happened. Finally it is a combination between software and hardware problems in this case.
I had in plan to update my other 2 boxes from SCV6 to SCV7a - but now i am afraid to do this, because i think all this is very unstable with this kind of hardware and perhaps i should stay with the SCV6 version now?
Any opinions?
Originally posted by chenrp View Post
this is beta. if your box is working, no need to update magisk...
I like to have always my important installations up to date.
until now, for me worked 14.0 and now 14.2 (which shows also beta) without any issue. And i am thinking to update to 14.3 now.
Originally posted by Pushkar821 View PostHi,
I like your rom and recently updated to v7A . I liked the SDR to HDR Option in old but could not found in this version. Is it disabled or missing ?
There are currently 3895 users online. 0 members and 3895 guests.
