Hello guys!
Hello SC and thank you for the great rom.
Just arrived the H96 pro + from banggood.
I install with burning tool the V4 and all work great, wifi 2g and 5G.
Now a help for other neewbes like me.
I try to reboot to recovery with installed app but no luck no rooted
I copy the ota V6 to a flash drive and from updater app I try to update,no luck again
The box just power off
Now the tip!
I unplug the power I press the reset button and plug the power, a miracle happen
It open in recovery and start flashing the OTA.
It reboot and now I have a working V6 Rom
P.S Sorry for my poor English!
P.S1 Thank again S.C and all you guys for helping me with the post's that you have write.
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Hello,
Can someone confirm this product is identical and can take this firmware? I have purchased from Banggood H96pro Plus, DDR4 version. https://www.banggood.com/H96-PRO-PLU...p-1100082.html .
Also I must use a USB A to USB cable for USB burning correct? it wont flash via SD
I have the same Version, this rom works.
I've flashed it with an selfmade USB A to USB A.
A few months ago I purchased a 4K unit and flashed it with this ROM: aml_7.1_s912_q9377-S912_KDMC_mac-20170809
https://mega.nz/#!ZTIGWABC!xgkGFOrWL…8XYdisAlwcb2WY
I was unable to get my Sony TV to identify and reproduce 3D movies played in the pre-loaded KODI 17.3. Apparently the TV doesn’t recognize the 3D signal, or it is not sent from the box.
I have two other boxes with which I successfully play 3D content in this same TV. A Vero unit (linux based) and a Tanix TX5 Pro (Android box).
As soon as I have a few hours to spare, I'm thinking of giving this SCV6 ROM a go. Have any of you experienced this issue with SCV6?
Have any of you tried to play 3D content successfully with any ROM in this box?
Thanks everyone.
Originally posted by chenrp View Post
found that it is ddr3.
where can i find the wifi chip 9377?
Originally posted by neutester View Post
Does your circuit board on the opposite side have a sticker with the label 3g+16g+9377 on it? Mine looks identical to yours and I have a sticker with that label on it on the opposite side. It would be similar to the label in Pugnetta's first picture above.
There are currently 2318 users online. 0 members and 2318 guests.
