    I never tried, but I hope it works.
    Playstore (free)
    or
    Apkpure, includes older versions
      Originally posted by X92-2GB View Post
      Basically it makes your phone or tablet into a WYSIWYG remote to your TV box. It is way cool, as you can be away from your TV and see every aspect while controlling it.
      I recommend enabling double tap to zoom on the access ability settings of the box, as the handheld device will need it for some selections that appear tiny.
      The only draw back is there is a 1 to 2 second delay for screen refresh, and depending on streaming app, it may cause a protection issue and drop the playback.
      I use an xposed module to turn off protection flag, but it does not turn off HDMI protection over secondary display.
      The app can run both over wifi and wired lan, though wired lan is a bit smoother, depending on how good your router can cross connect between wireless and wired connections. Some delay may be more noticeable between the connections.
      i use an older app, because my tablet is 4.4.2, though the latest version seems to run on the box, i chose not to, as i like the older version interface.
      It is on the Google play store and apkmirror site.
      i prefer using a mouse
        Thank you for this info, however I'm wanting to use this tv box in a car pc project using a 7" lcd screen with USB touch overlay glass... my understanding is that the multipoint touch support needs to be built into the kernel itself. Using my phone to control the android box would be redundant in this project...
          Anyone here have issue with youtube for androidtv, using ver 1.3.11 and occasionally cant play video on Lan network but when I change to wifi problem resolved.
          Anyone else same have issue?
            I’m always using WiFi, and no issues. But I’m using the latest YouTube without ads version from xda
              Thx but I m using androidtv version, I pressume you are using vince version or smart youtube here.
              I dont have problem with wifi to play youtube, however my box is always connect with lan to play videos from NAS and I prefer youtube interface whkch easier for remote instead of touch that req. mouse.
              I will try reinstall the youtube again.
              Thanks.
                Hi Guys,
                Can anyone help me to get a SCV4 GREEN (LPDDR3) PCB IMG?
                  Originally posted by thipolito View Post
                  Hi Guys,
                  Mission impossible!
                    Originally posted by lyubodelev View Post
                    Mission impossible!
                    Why you say it is impossible?
                      Hi Guys,
                        Yes I noticed that SCV4 GREEN (LPDDR3) PCB IMG
                        is not available and that's why I asked for help...
                          If you are shure, your box is with LPDDR (ones more SHURE!!!), than try the blue image file. The color of the plate is not so important!
                            Tried already but gives error...
                              Can you send a photo of your plate?
                              2 photos from both sides!
                                Pictures attached
                                Thanks Click image for larger version
Name:	SCV4 GREEN (LPDDR3) PCB IMG - SIDE1.jpg
ID:	743091Click image for larger version
Name:	SCV4 GREEN (LPDDR3) PCB IMG - SIDE2.jpg
