IT WILL HAVE LOTS OF BUGS..... AND STILL LOTS OF WORK NEEDED!
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
THIS IS A VERY EARLY BUILD SO IT WILL HAVE LOTS OF BUGS!!!
FOR OTA SCV2 UPDATE TO WORK YOU NEED TO BE IN SCV1, YOU CAN USE THE ROM UPDATE APP TO DO A LOCAL UPDATE OR SIMPLE REBOOT TO RECOVERY AND DO IT!
Changelog V2:
- Manly codec fixes.
- Crash with amcodec on FTMC and SPMC fixed.
- Updated framework and some libs
- Cpu Temp should be even better now!
- Faster EMMC read/write
- And other small things.
- Mouse mode on the remote IR not working! (on todo list)
- Dont update Netflix or it will stop working, that you need to "talk" with netflix for the stuff they are doing...!
- The RGB in Display setting its not working! (on todo list)
- Lighthome m8 crash if you try to use the file icon on main screen! (on todo list)
- LOTS OF OTHER BUGS.....
Changelog V1:
- Not based on stock, this one is 32bits ( but based on other very recent 17 may build )
- Added Twrp ( Thks me and abdul_pt .. still beta )
- Only 1 launcher now ( lighthome )
- Proper root ( SuperSu 2.81 )
- I think this one is more stable and cooler that the 64bits one, you dont see the diference between the 64bits and 32bits!
- True 8 core, all cores at 1.5Ghz
- Gpu OC to 792
- Auto hide the task bar, navigation bar can be enabled in the settings.
- Blue button on the remote brings app switch to close open apps press the x button on the remote ( the button near 0 ) - sorry gt1 guys i dont have a gt1 remote and i this theirs not enough free buttons to map...
- FTMC 16.2.28
- Fully deodexed
- Should be lot smoother!
- Default IME is now the stock white one (AOSP one)
- CPU/GPU temperature should be a lot better now, but since the GPU is OC and all 8 cores at 1.5Ghz its still a bit hot!
- Fixed adb
- Netflix, youtubeTV, playstore...etc... fully working
- Youtube 4k support
- initd.d support.
- Fixed a google framework crash.
- Added PS3/PS4 support but only with cable! (press the playstation button on the remote to enable it)
- Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
- Permissions fixed.
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- and other little stuff under the hood!
- SuperSu on the 1º boot might say that su its busy and root not working, if it does that a simple reboot fix it and the problem dont show anymore.
- In FTMC or SPMC you need to disable amcodec or else they will crash on some type of files!
- DOWNLOAD HERE OTA SCV2 Beta 7.1.1
- MD5: 49C0A4386CAA9D6F11FC943DDEDBF5D7
- DOWNLOAD HERE SCV1 Beta 7.1.1
- MD5: D00BDC9290ED7D09BE10A6FD0173371A
- Use usb burning tool....
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
