[ROM] Beelink GT1 / Alfawise S92 - 2/16 - SCV2 BETA 7.1 ( 9377 Wifi Chipset )
Originally posted by bahus View PostDoes it mean you compile it yourself from the Beelink sources? I have this nagging me issue that CEC TV remote menu key is not functional because it's incorrectly mapped to key code 178 (SETTINGS) instead of key code 82 (MENU). I believe it can be easily fixed in sources simply by find and replace operation (178 -> 82).
in the featurelist stands:- True 8 core, all cores at 1.5Ghz
- Gpu OC to 792
does this mean normally all other firmwares dont use the full 8 cores, how much are normally used and at what clock ?
What is the normal clock of the gpu at stock ?
is it possible to clock down to default as user of this image?
is exfat supported in this image ?
i hope this were not too much questions ;-)
best regards,
Thomas
Originally posted by FunThomas View Postin the featurelist stands:- True 8 core, all cores at 1.5Ghz
- Gpu OC to 792
best regards,
Thomas
They use 4 cores at 1.5ghz and 4 cores at 1ghz, and stock gpu clock is 666mhz!
I haven't tried the second iteration of the new build yet, but this is the first ROM build that has worked consistently on my buggy Alfawise S92. My box would intermittently lose video (screen goes black) during build setup and while streaming selections in Kodi or FTMC; this would occur regardless of what ROM I flashed it with, OEM or third party. It seems (hope I don't jinx it) that my prayers have finally been answered; thank you Superceleron!
Originally posted by goodjob View PostI haven't tried the second iteration of the new build yet, but this is the first ROM build that has worked consistently on my buggy Alfawise S92. My box would intermittently lose video (screen goes black) during build setup and while streaming selections in Kodi or FTMC; this would occur regardless of what ROM I flashed it with, OEM or third party. It seems (hope I don't jinx it) that my prayers have finally been answered; thank you Superceleron!Last edited by superceleron; 05 June 2017, 01:28.
Hi superceleron,
this image looks for the first test very stable. The videoplayback (only full hd) are as smooth as the V8C version. Audio passthrough is also working fine. When i press the blue power button on GT1 then sometimes comes the camera app and not the shutdown option. The OTA Update app ist a bit strange from the font size and the translation, so i took the TWRP and all is fine
I have the 6255 Wifi but using it wired so i cant say anythink about wireless.
Is it possible to clock the gpu at stock clock or how can i check the temperatures of the gpu/cpu?
EXFat Filesystem is not supported at the moment, will be there some chance to get it with the next version ?
Thanx for this great image !
superceleron It seems something wrong with TWRP. I see no internal SD Card nor attached USB drive. Only external SD card is mounted. I see in log error 127 on internal sdcard mount.
FunThomas Regarding USB maybe you are right - it's some old FAT16 usb stick (which works OK in Android). But there is something wrong with internal SD card. I see root folders in TWRP but I can't access /sdcard folder - it's empty. So no access to standard Download folder (/sdcard/Download).
Thks for the feedback, and yes TWRP still have some problems... that is why that is still a beta.
About the remote... that is a big problem i dont have the orginal remote LOL, so what i do is trial and error with my beta tester but still its time consuming and not the same as me having the remote!
Temperature use the included app "andboost" it will show the cpu temp that is the same as showing the gpu temp since the 2 are in the same chip.
Default gpu clock? to hot? i will make a update zip only true 8 core and default gpu mhz when i can!
Exfat maybe when i get my hands on a proper A7 Kernel!
There are currently 2198 users online. 0 members and 2198 guests.
