[ROM] Beelink GT1 / Alfawise S92 - 2/16 - SCV2 BETA 7.1 ( 9377 Wifi Chipset )
Guest
Superceleron, ao definir o idioma para Português e desligar a box, quando ligo novamente fica com idioma parecido com Russo.
thanx superceleron
so the difference is only for the chance of bad flashing since there is no more check of the flashed image ?
so if everything works fine like in 98% of the cases its the same but the rest 2% will search why it doesnt flashed good and the reason was the bad sd card ?
There are currently 2962 users online. 0 members and 2962 guests.
