[ROM] Beelink GT1 / Alfawise S92 - 2/16 - SCV2 BETA 7.1 ( 9377 Wifi Chipset )
Originally posted by sesdave View PostHi - just giving this rom a try on a couple of s92's. Initial view is that it seems pretty zippy - nice work. Running my IPTV packs very nicely using all format full HD player. Do you have a download link for the V8C wallpaper on launcher 3? I have kind of grown used to seeing it. Thanks
Pity i cant use webos launcher on it, dont work well on 7 (showing its age)
Originally posted by trebor View PostIf you have a read post
http://freaktab.com/forum/tv-player-...388#post649388
Yes by the looks...remote and clock, is the only downfall.
Wonderful to have you back working on our machines Superceleron!! Though that you have forgot us!!
Some things I want to mention, first the Sleep option for me it is not suitable. Thats because I press F10 on my Rii to Sleep the machine and then I cant press F10 again to recover but PowerOn from the remote.
Second one is about the keyboards on screen. I disabled the virtual keyboard from the options and not showing anymore but I cant press Ctrl+Space to change between languages as before to my Rii.
Final the Youtube application (the one tha come installed) has some breaks when playing on 1080 60 frames per second.
Other than that, the ROM seems very stable for everyday use and seems to working fine. 4k Youtube is perfect (my connection is nott xD).
Thank you and keep up the good work SC.Last edited by johnickz; 02 June 2017, 19:20.
Guest
Superceleron, i installed with sucess on Beelink GT1 with serial number G912.
Works super smooth, tonight i gonna do some tests. Netflix works well on SD res.
Great job and thank you!! you are the best!
Gratz
Originally posted by johnickz View PostWonderful to have you back working on our machines Superceleron!! Though that you have forgot us!!
But i dont have a remote for it.. so it m8 have some problem there.. lol
And thks for the feedback i will check it with some more time
Originally posted by natao2008 View PostSuperceleron, i installed with sucess on Beelink GT1 with serial number G912.
Gratz
And no im not the best their lots of others better than me
superceleron There is going on active discussion in Russian forum regarding stuttering on playing high bitrate stream videos (like Torrent TV, hls). And there are two possible solutions:
1) Add the following line to init.amlogic.board.rc
Code:write /sys/module/amvdec_h264/parameters/error_recovery_mode 1
Dunno what can be done about #2 but can you do #1 in your firmware?
Originally posted by rubioario View PostThis version works in GT1 Ultimate ddr4 S912 ?
Originally posted by bahus View Postsuperceleron There is going on active discussion in Russian forum regarding stuttering on playing high bitrate stream videos (like Torrent TV, hls). And there are two possible solutions:
This is droid 7, are you sure than that still happen with this one?
superceleron I didn't test your firmware yet. But I saw this problem ("slideshow effect") on Android 7 stock beta firmware . Do you know about some negative effect of this "fix"? What's not to like? :-)
Originally posted by bahus View Postsuperceleron I didn't test your firmware yet. But I saw this problem ("slideshow effect") on Android 7 stock beta firmware . Do you know about some negative effect of this "fix"? What's not to like? :-)
There are currently 2096 users online. 0 members and 2096 guests.
