Many thks to gearbest for sending me the device to play
Many Thks to my beta testers trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
I DO RECOMMEND AFTER 1º BOOT, CONFIG YOUR STUFF AND REBOOT THE BOX IT WILL WORK BETTER AFTER THAT!!!
Changelog Beta V1:
- Based on 40% of the stock rom
- General optimization.
- Should be a lot smoother than stock one!
- Fixed emmc cache/system mount problem!
- Cpu Temp should be better.
- Fixed almost all video playback ( Youtube included 1080p max sorry... this box due to one codec issue not fixable by me dont play 4k youtube.. so dont ask for it )
- ADB fixed, network and cable.
- Added power button to navigation bar, single press = sleep, long press power menu.
- Android TV feel ( Dark pop ups etc.. )
- Auto Hide of navigation and status bar, so dont show anymore on Youtube and other apps!
- Proper root! ( Update SuperSu binary that will make the box boot faster! )
- Organized some boot scripts.
- Added lots of kl's.
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Netflix, youtube, playstore...etc... fully working
- initd.d support.
- Gapps updated
- Xbox360 Gamepad Wired and Wireless support.
- Gaps Updated
- Permissions fixed.
- Added Xposed Framework
- FTMC Build 29 ( Dont forget to enable ALL RKCodec stuff in settings )
- - Fixed H265 playback
- - Fixed VP9 playback ( only on RKCodec )
- Permissive mode!
- Added a few apps...
- And a lot of other stuff.
- For Screen Scale you need to go to box settings ( the one with a white background and purple? cogwheel in main screen ) and in "Display->Screen scale"
- If font is to big go to settings ( the cogwheel in the bottom of the main screen ) then "Display->Font size" and change to the one you like must... for me is the "Normal" one
- FTMC crashes playing H264 10bit files with RKCodec enabled, that is a problem of the lib in the firmware and not a FTMC problem.. not fixable for now, so plz if you want to use for read H264 10bits files disable RKCodec in settings.
- FTMC dont show the temperature, that is a bug in the kernel!
- And i bet a lot more Bugs...
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV1-Beta for the Alfawise H96 Max
- MD5: 010E341C6F6C15008E28731005BA31A7
- The USB3 port ( Blue one ) is the OTG port for flashing!
- The rest search the forum for instructions!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
