we are wating your udpate ....
[ROM] AlfaWise H96 MAX Android 6 4Gb/32Gb - SCV1 Beta
tv box h96 max starts going 10-20 minutes ,
one hour after ...it blocks itself,
does not respond to any orders, just the clock goes to the screen, nothing can be closed
I immediately remove it and plug it into the socket and it stays stuck on the H96 max logo,
after it needs to be rescued again
I gave her firmware update
after 5 minutes an hour or half a day, and it remains stuck in an application, after freezing, only the clock goes to the screen, pull it out and put it back in the socket after it starts and remains locked in the logo h96 max
I tried the latest software and still doing the same goes what goes on youtube, or kodi or chrome, after frosting I pull it out of the socket it bag again and it starts up to the h96 max logo after it has to be firmware update please help me
Originally posted by Liquids69 View PostHI Guys
..i plug it in and the only RESOLUTION i have is 848x480p60
...and i dont have any setting two change ..some one have issus like this??
I had the same problem with my H96 PRO PLUS... when I moved it from my 4K TV to a 1080p PHILIPS TV.
One time I was able to make it work by Pulling out HDMI cable while "FORMAT NOT COMPATIBLE" message was on Screen, and then Plugged it back it.
It didn't work the next day.
The REAL solution came from Plugging it back into 4K TV and Going to DISPLAY in settings, and changing HDMI Resolution to 720p... and TURNING OFF "AUTO" in HDMI Resolution. (Sometimes these are both on SaME Screen).
Then I reboot while connected to 4K TV to check if it restarted in NEW settings of 720p. Once I confirmed this, then I moved it to 1080p TV and plugged it in and re-Started.
PERFECTION!
Turns out Box was trying to use 1080p REsolution when TV was actually 1080i Resolution.
So now I moved Resolution on Box to 1080i and it worked even after restarting Box! Hope that helps!
my h96max 4g 32gb (not alfawise, rockchip) has no sound, only 1024x768p res. on Samsung 55es7000 tv.
can i install this fw? solve my problems?
is still same useless launcher in this custom fw?
guess top, bottom bars can be used in this one? bcs stock rom doesn't have any of these notification, navigation bars.
Originally posted by riven4300 View Postmy h96max 4g 32gb (not alfawise, rockchip) has no sound, only 1024x768p res. on Samsung 55es7000 tv.
good luck3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Originally posted by michael2t View Post
Sounds like a bad HDMI cable pick up a new one from the store ...it fixes my issue
good luck
maybe someone who solved these no sound, low res problems, can tell this fw fixed issues or not.
other hand i can install on rockchip h96max 4/32gb device, right? does it matters to be alfawise branded tvbox? bcs looks same. any difference?
i just installed this . sound ok, 1080p ok now. using another launcher.
my issues now;
almost %60 apps can't be installed in googleplay. says can't compatible with my device. why?
is this fixed in 7.1.2 fw.
can't get in developer options, kicks me out when i selected, enabled at about device already .
can't download/save files directly to sdcard, usb folders, only own nand drive by opera or adm download manager. is this android 6 limitation. it was not problem when using 4.4 kitkat tvbox. any solution for this?
Hi Superceleron
A little help needed please. I have your Alphawise H96 Max SCV1 Beta firmware installed and working but no wi-fi. This Firmware has the ap6255 and I need to change it to the q9377. Can you or someone point me in the right direction, ie with software or editing?. I can see the wi-fi number looking in the sys directories but it will not save after editing it to q9377, says insufficient memory.
Regards jb
There are currently 2054 users online. 1 members and 2053 guests.
