And i cleaned the rom dunno what is that china tunnel!
[ROM] AlfaWise H96 MAX Android 6 4Gb/32Gb - SCV1 Beta
Hello SuperCeleron,
Can You add magisk root to this rom too ?
Michael T.
3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
For that is need to have a twrp build(good one...)
Im busy now with other stuff, if i get some free time i will try to make one!
Michael T3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Ok I downloaded the rom the drivers (Rockchip Driver Assistant 4.1) and the factorytool 1.39 but for some reason the drivers refuse to stick on my windows 10 PC and my windows 7 laptop
no matter what I try the box boots with the recovery button and usb plugged into the (blue) USB 3.0 port and device manager shows an unknown device and factorytool and RKbatch tool never detect the device
is it possible my box is bad and not actually going into recovery ? I have used the same USB cord to flash a Beelink just a couple days ago but it had the S912 in it.
any hints or tips would be great..
OK I got it with the 4.4 Driver Assistant on the Window 10 PC
Rom is running smooth wifi works updated SuperSU and installing apps nowLast edited by clsA; 02 August 2017, 21:31.
Update ... the Rom works really well except the darn autohide notification and launch bar are nearly impossible to get to show, it sometimes takes dozens of tries and gets very frustrating when your just looking for the recent apps button. Thanks again for making this rom it really is 10x better than stock.
Originally posted by superceleronwell im now going to make a A7 rom for this one.
Lets see how it goes!
If you need a tester I'm available.
The current Rom is working really well.
I brought this as a replacement to my Fire TV that got took out by lightning.
N64 emulation is working pretty good at 640x480
GTA SA and VC are running steady 30fps with everything set to 90% and Medium
FTMC works nice and smooth, much faster than Kodi 17.3
File copy from ext.sd to internal is lighting fast
Box seems like a keeper to me, it's much faster than the s912 I bought first. But it was twice the price so it's a tough decision.
Bottom line is if emulation is important to you this is worth the extra money but kick in a few bucks more and you have a Nvidia shield
Sent from my LEX727 using Tapatalk
Just installed this ROM instead of the Android 7 ROM, and have immediately hit a different problem, also very major
In Play Store, many vital apps are saying "not compatible with this device"
It won't let me install any of the following apps :- UFC (Ultimate Fighting Championship)
- strongSwan VPN Client
- OpenVPN Connect (but I can install the unofficial OpenVPN for Android)
- NordVPN (my VPN provider)
- UKTV Play
- All 4
- ITV Hub
- Radioplayer - Free UK Radio
- BBC iPlayer
- BBC iPlayer Radio
- YouTube - I uninstalled the one you provided to see if I could re-install it, and I cannot.
- .. and many others I haven't bothered to list.
The pattern seems to be: network/VPN related apps (but not all), and video player apps?
EDIT: Even Google Chrome can't be installed!?
Any idea why this is happening? I could install these apps fine on the H96 Pro+, in both Android 6 and Android 7.
Is there some change I can make to build.prop to make these apps compatible? (Or maybe it is related to DRM? - I just saw some mention of missing DRM in a YouTube review of the H96 Max.. But then why Chrome and VPN apps??)
If this is expected then clearly I should have researched the H96 Max more before I purchased itLooks like it is nowhere near as usable as the H96 Pro+.
But it just seems crazy that even Google Chrome can't be installed - surely a bug?Last edited by TheBloke; 15 August 2017, 00:44.
Originally posted by TheBlokeI made a post that hasn't appeared - could a mod please enable it? I guess it was blocked because I put a number of links in it (all to Google Play store).
I want to add some more info, but it won't make any sense without the original post.
All you have to do is install the app you need from a website like apkmirror or apkpure
You can also use es file explorer and backup the apps you want on the 96pro+ to a flash drive then move the drive to the new box and install them
Originally posted by clsA View PostAll you have to do is install the app you need from a website like apkmirror or apkpure
But of course this is hugely inconvenient - I have paid-for apps that I won't be able to get unless I find a pirate copy, and then I will have to keep re-downloading them to get updates rather than have them just auto-update. And even using Aptoide for the free apps relies on up-to-date apkmirror etc copies being available soon after Play Store is updated.
However it might also be good news - if they apps do work, then surely it's just a minor bug that causes Play to think they won't? Some settings change that can be made to make Play know that this device supports all these apps? Eg build.prop or whatever the main settings file is called.
However, I am not yet sure that all the apps do actually work. I installed BBC iPlayer and YouTube ATV from Aptoide and both seem to be fine.
But I also installed OpenVPN Connect, and although it opens fine, there's no visible menu. I can't configure it or use it in any way because I can't find the Settings menu, it's just not visible. I tried various keyboard shortcuts as well, but couldn't find any way to get a menu to pop up.
Something weird is going on and I wish I understood what was different about the H96 Max. No doubt SC can explain though.
I will go test some other apps as well.Last edited by TheBloke; 15 August 2017, 15:48.
There are currently 1915 users online. 0 members and 1915 guests.
