[ROM] Mecool M8S PRO+ Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by Boleh View Post
I am using the other Android TV build but I believe the core is the same
Although I don't have this gray bar issue in Netflix, but my box would randomly reboot while watching Netflix.
Does this ever happen to you?
The only problems I have with this box are Netflix related
Finally I installed a ROM on my box despite being part of the faulty stock
My box came with the KLMAG1JENB - B041 chip and the 20170815.182813.V0321 firmware then I updated to the latest OEM version 20171128.111200.V0928 via OTA
everything without any problems so I decided to install the Nano ROM via OTA because I couldn't do it via Burning Tool
then I did all the wipes
And it works just perfect I love it!
I feel like trying the Android TV version but I don't want to abuse my good luck with this version
I'm having a few problems some didn't happened while I had the stock version some I'm sure are problems from the stock version :- Netflix TV has a gray bar at the bottom
- After streaming a video for about 1 hour on Kodi the app freezes
- The power button turns off the box instead of put it in stand by
- My air play remote can't turn on the box
- The mouse cursor somethings "jumps" to a corner by itself
- I can't use Netflix (the TV version and the normal version) while I have the box plugged via AV/Out
- When I have the box via AV/Out the mouse cursor looks massive
Anyone knows how can I fix any of this problems?
and sorry for the REALLY long post I wanted to be specific about my experience with this box and ROMYou may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosLast edited by Bllq21; 29 December 2017, 05:36.
Hi, I just updated my M8S Pro+ 2GB/16GB with the 20171216 release and I can't seem to connect using Ethernet.
On power on, I can see the connect light on my network switch light up correctly for the port where my box is connected. But somewhere during the boot process, in the middle of the Nexus booting animation, the LED on the network switch turns off. When fully booted, the system will tell me Ethernet isn't connected no matter if I try to unplug and plug back the cable, on either end.
Only Wifi works but I'd rather connect it via Ethernet.
Any ideas why it's behaving like that?
URGENT HELP
How do I return to stock?
The frequency of Netflix crashes are getting infuriating. Please help.
I've tried System -> About -> Update and selected the OTA ZIP. Rebooted int TWRP but during flash I got the error "This is for M8S_PRO_PLUS device but this is p21x"
What other method can I use?
p21x
All Amlogic repository
You have to use one of Magendanz "fixed" OTA updates.
p21x
http://freaktab.org/3~f
Bad news is that the Netflix issue persists! with a small difference. Instead of the box going into reboot, the Netflix app would randomly show the error "Could not reach Netflix service (-114)"..
No issue on LibreElec/Kodi 18/Netflix addon; but resolution is limited at 720P
Thanks. I have managed to return to stock now.
I just tried both Nano and Stock and both worked. I ended up with two boxes - a 1/8 GB and 2/16 GB. I got the 1/8 on E- bay and it came "preloaded" with someone else's Netflix and GMail accounts and auto logged in to both. It was advertised as new but obviously it was used. It had a ROM dated 0717 IIRC and it didn't have the flashing problem. I think the chips have "Samsung" on them but I don't recall the other info. It also has a reset button. The 2/16 box (still) has the 0919 ROM and no reset button. I am almost afraid to try flashing it. I think I will play with the older box for awhile first. Also think I will go back to Nano, too much stuff I won't use on Stock. Oh yeah, I flashed using OTA from and SD card. I also use adb to reboot into recovery, sideload Netflix, etc.
Unfortunately the only reason I got this box was to try to download Netflix videos in HD. I have an internet connection that is too slow to stream HD so I thought I could download and avoid buffering. I actually got some version of Netflix to download in HD but it only had 2.0 audio not 5.1. I think this is because Netflix only intends downloading to be on mobile devices that only have two speakers (although there are some Android tablets that support 5.1), I might have to download videos using Kodi or Terrarium.
Anyway, thanks Magendanz for this.
#180.1Guest commented09 January 2018, 01:56Editing a commentWhen updating from stock OEM firmware, you should ensure you've done a data wipe so that you don't have any residual preinstalled apps.
As for Netflix, I recommend the TVStock variant so that you get Netflix for Android TV. That seems to deliver HD more reliably, and the user interface is better designed for a remote control.
There are currently 2234 users online. 0 members and 2234 guests.
