[ROM] Mecool M8S PRO+ Stock & Nano Nexus ROMs (Android 7.1)
    Changelog (20180706):
    • Updated to latest M8S Pro+ OEM firmware (20171208.183013.V0928)
    • Updated to TWRP Recovery 3.2.2-0 using latest OEM kernel
    • By popular demand, included OEM Miracast app
    • Latest build from Open GApps (20180706)
      Guest Will you upload also an ATV version of this rom?
      • Guest's Avatar
        Guest commented
        Editing a comment
        Yep, hopefully later today.
      im new here..my m8s pro+ doesnt have status bar..build version of my box is 20171124.183803.V0928. So can i use nano ota to get the status bar. it will be new interface right? pls help me
        Thanks, Magendanz! You're the man!
          Guest ,will the M8S Pro L get any joy anytime soon please?
          • Guest's Avatar
            Guest commented
            Editing a comment
            Yeah, that's next on my list. The trouble is that we've now got two kernels on that box, one for each wireless chipset.
          So, has anyone been able to get sleep working on this box using this technique? While it apparently works on the M8S PRO W, it's not working for me on this latest OEM firmware for the M8S PRO+.
            I think that different wireless chip exist for some time already. Friend of mine is unable to install any of your mod. Wifi is not working. He had to rollback to older one (from september?) and flash img from pc to get this back.
              does chromecast work now?
                Hi, did anyone figure out yet how to get sound from a bluetooth dongle?
                The dongle connects to my earphones, but no sound.
                FYI I'm using usb bluetooth dongle, would a dongle in the AV port work?
                  try soundabout app
                    Hi magendanz can you please recompile the kernel with dvb usb. I can run tvheadend with this rom but it's not recognize the usb dvb tuner
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      The firmware is rooted. Just find the driver (kernel module) you need and place it in /system/lib/modules. (You might also need to add an insmod call in your init.amlogic.rc.)
                    I installed the new firmware and image, now the Mecool logo disappeared only Nexus is seen, this is normal right?
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      Yep, I've got a custom boot logo that replaces the Mecool one.
                    Hi i can't find my stick geniatec t230 driver can you please help me
                      Hi. My emmc chip is FORESEE, I should be ok installing this right?Click image for larger version
                        Hi Guest ,
                        I'm looking for the TWRP version for the Mecool M8S PRO+ to be able to install/root Magisk by myself.
                        The link to TWRP on the first page is broken, could you give me a link ?
                        I know that TWRP is included in the modified firmware but for some reasons I want to keep the stock firmware for now that's why I'm looking for TWRP alone.
                        Regards !
