Originally posted by sweetnonso View Post
Is this box originally Android 6.0 please?
#19.1Guest commented29 July 2017, 18:11Editing a commentWell, not any S905X device, but a 1GB M8S Pro+ should be fine. I haven't tested with that hardware, but the OEM firmware that this is based on was created for both 2/16G and 1/8G configs.Last edited by Guest; 31 July 2017, 02:17.
Originally posted by longnt View Post
Yes, it's come with Android 6.0. Look at this thread to upgrade to 7.1 first then you can use this rom
No, I don't believe that you can apply this ROM (for the p21x reference board) to the Mini M8S II (which uses the p212 reference board). Basically, I don't believe the kernel and device tree are compatible, and I assume that there was a reason that Amlogic felt the need to rev the reference boards for Nougat.
If I can find an OEM Nougat build for p212, I can use that as a foundation for custom ROMs on those devices. Beelink was nice enough to publish a Nougat build for the GT1 (q201 reference board) and my goal is to bring Android TV 7.1 to that next.
Guest Thank you for this new ROM!
I have a new A95X 1G/8G S905X that I'd like to try this on. Would I be OK putting this ROM on it?
Like Magendanz said, there is incompatiable between p21x and p212 board, you must find Nougat build of p212 first. I already point to U2+ 905x firmware thread that make all p212 boards can run on Nougat build. After that you can mix bootloader, kernel, dtb from p212 boards with system from this p21x rom to make your p212 run Android TV 7.1.1 like me. If you want to know how to do, here is the guide:
Requirements:
- Know to use AML Burning tool to upgrade your device to 7.1 with U2+ image first (there is a mac license check you must know mac address of your box too, usually a sticker on back side print these mac address).
- Know to edit and repack zip.
- Know to use TWRP to install zip file and copy file (to fix remote).
- Backup /system/etc/remote.conf from your current working rom.
How to install:
- Flash U2+ firmware and make it boot first time (because you have been erased all so you need to boot to make bootloader format your data partition).
- Edit and repack this rom, open updater-script in zip and delete all lines except this line (for disable device check and disable overwrite bootloader/kernel/dtb from p21x firmware):
block_image_update("/dev/block/system", package_extract_file("system.transfer.list"), "system.new.dat", "system.patch.dat");
- Copy TWRP recovery.img to sdcard and boot to TWRP (insert sdcard then hold recovery button while plug the power on).
- Use TWRP to install modified zip file.
- Mount system partition, copy your backup remote.conf to /system/etc. You will stuck in Setup Wizard if your remote not work, somehow Magendanz have been disabled TouchUI in framework-res.apk so mouse doesn't work too.
- Reboot and enjoy Android TV 7.1 on your T95N, T95X, Mini M8S.... or whatever p212 boards which can running U2+ image.
Warning: DON'T WIPE DATA IN TWRP or you will make your box become soft brick (need AML Burning tool or Burn card maker to recovery).
Some pictures that I'm running this romYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by longnt; 30 July 2017, 05:52.
OK, so just to be sure.... I currently have installed this ROM 'update_MINIMXIII-II_112M0_TVStock-20170606.zip'. Can I download 'M8S_PRO+-V0321_TVStock-20170727.zip'. boot to TWRP recovery, wipe and install this?
Thanks, Andy
Guest
Originally posted by ADB View PostOK, so just to be sure.... I currently have installed this ROM 'update_MINIMXIII-II_112M0_TVStock-20170606.zip'. Can I download 'M8S_PRO+-V0321_TVStock-20170727.zip'. boot to TWRP recovery, wipe and install this?
Thanks, Andy
- Vulkan: S905X use old Mali 450 which only support OpenGL ES 2.0, only S912 benefit this.
- PIP: In media_codecs.xml tell us that S905X only support 1 video decoding stream so PIP not really work (Live channels playing in backgroud will make Youtube not playing anything).
- Recent apps: I don't think Android TV need this feature.
- Live channels: Now it can recognize Full HD UDP multicast stream instead downscale to SD like Android 6.0 framework.
There are currently 3780 users online. 0 members and 3780 guests.
