Used the USB burning tool v 2.0.8 to install your IMG version, what a pain. For whatever reason, it is hard to get my computer to recognize this box. Per your earlier suggestion, I use the round end of a large paper clip, and it works well to depress the "reset" button. From others suggestions, I "started" the tool prior to connecting the box to my computer, on my MeCool M8S Pro PLUS, the OTG port is the USB port the farthest from the microSD card slot. I have to keep trying different USB ports on my computer, and the hardest part is waiting a minute or so after I plug into the USB port on my computer, it finally takes, and I can install the firmware.
Originally posted by Magendanz View Post
Used the USB burning tool v 2.0.8 to install your IMG version, what a pain. For whatever reason, it is hard to get my computer to recognize this box. Per your earlier suggestion, I use the round end of a large paper clip, and it works well to depress the "reset" button. From others suggestions, I "started" the tool prior to connecting the box to my computer, on my MeCool M8S Pro PLUS, the OTG port is the USB port the farthest from the microSD card slot. I have to keep trying different USB ports on my computer, and the hardest part is waiting a minute or so after I plug into the USB port on my computer, it finally takes, and I can install the firmware.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Feedback - M8S_PRO+-V0321_TVStock-20170825.zip - using TWRP Recovery.
Android TV Icons and text too damn small - I had to re-edit the build.prop for a lcd.density=298 so my dodgy eyesight could see stuff properly.
240 density is far too small for Android TV use when sitting a normal viewing distance away in an Armchair.
Selecting "About" in Android settings, crashes the Settings App.
"Mute" button on IR remote and my Wireless remote does not work. OSD Volume Pops up but no Muting, even when PCM only Audio active in Android settings.
I re-installed Magisk3.x.zip...
Android TV - 1080p Netflix still works with EAC3 5.1 Audio
Code:08-29 12:33:56.050 3977 7086 D AmlogicVideoDecoderAwesome: omx output size changed from 1280*720 to 1920*1080
Good feedback!
I'd love it if I could get some repro steps for the crash in About, since I can't reproduce that myself.
I was curious what Magisk would do, since this new ROM comes pre-rooted from the factory. Hopefully, it will allow you to mask root for apps like Netflix. Did you notice if you were getting 1080p from Netflix before you installed Magisk?
I had 1080p Netflix with the previous OTA Update before and after installing Magisk made no diff.
I effectively did a factory reset in TWRP on last OTA update and Settings > About worked once and once only.
Once I installed an App I could never get About to display any Info without crashing. Been the same way ever since. Not too big a deal.
If I get time I will have a good look in Logcat to see what is causing crashing.
Originally posted by Floki View PostDid I understand this correctly? The only way to get Netflix in 1080p is:
- Install Burn Package + Magisk
or
- Install OTA Update
Is this it? Is one option more recommended than the other, or is it exactly the same?
Thanks for all the work!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by wrxtasy View PostFeedback - M8S_PRO+-V0321_TVStock-20170825.zip - using TWRP Recovery.
But, yes, I do remember having to change the display density on some of my other Android boxes a few generations back. I would have to go into the build prop and change the settings, because the text was too small to read.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Official Android TV devices, Shield, Mi Box, Nexus Player etc.. use a lcd.density of 320
This ROM uses a normal Android OS lcd.density of 240
That is a 25% shrinkage in the scaling of the GUI displayed.
If you don't believe me simply count the number of Android TV App Icons that can be displayed on the home screen horizontally with this ROM vs say a Android TV - Mi Box.
There is a clear difference in GUI picture scaling.
First of all, many thanks for the work in this awesome firmware. Netflix in 1080p and Youtube in 4k in a cheap TV Box is really amazing. I hope it would be possible someday Cast and DLNA make to work. I found another mistake with HDMI CEC. Only works a few seconds after boot.
Thank you again for your time and work.
Can you confirm that CEC bug also happens in the 20170815.182813.V0321 OEM firmware? https://mega.nz/#!rEU1SSBS!EGUpAkti-...Eia2Er0AxuuH5g
I did nothing special to get Netflix to play in 1080P, just did a clean install using the burning method. Went to the Google Play store, and downloaded the Netflix that is there, walla, 1080P.
I have libreElec running in SD card, i wanted to install this rom too. how can i do it? can i install it with Update app in internal storage? and if something goes wrong how can i install stock rom again?
I tried to install twrp recovery but it stay in Mecool Icon nothing happens... anyone can help me?
Thanks in advance
Yes, you can flash this ROM to the eMMC using the Update app. (Remember to check the data wipe option the first time.) After that, you can always revert to the OEM firmware using this .img file here: https://mega.nz/#!rEU1SSBS!EGUpAkti-...Eia2Er0AxuuH5g
There are currently 2215 users online. 0 members and 2215 guests.
