    Originally posted by pawnthep View Post
    wrxtasy About systemcontrol problem, I see in your http://wrxtasy.libreelec.tv/MECOOL/ there is a systemcontrol file, will this has to do anything to fix the problem.
    If so, how to apply it?
    BTW, for changing to 320 density and fixing auto refresh rate, using Kernel auditor app can do all this with ease.
    I thought this ATV ROM was Rooted, so I had a look at this App (Kernel Adiutor) but Root Check and KA both say Not !?
    Also Settings:About crashes the Settings App every time ? Should there be 2 Settings Apps in the System Apps list ?
    Ta,
    Pete
    • Guest's Avatar
      Guest commented
      Editing a comment
      It's not clear to me why they're having so much trouble detecting the factory root, but I can go into Terminal and type "su" and then use dd to image the partitions. That's pretty effectively rooted, in my opinion.
    Originally posted by Magendanz View Post
    Yes, there's a bunch of tuner drivers in the NVIDIA Shield TV firmware that we could potentially borrow.
    I was hoping that would be the case. As soon as mine arrives (maybe Wed) I'm hoping to start testing this exact option!
      I like the ATV front end, but it's such a pain installing non-available apps on another device and then extracting and transferring to ATV ...
      Install an Alternate Apps Store like:
      Find, discover and download the best apps and games for Android in the official Aptoide app store
      You can directly install a bunch of regular tablet Android Apps then.
      I also suggest installing a Rotation Locker App for tablet Apps that insist on running in Landscape mode instead of Portrait.
        Well I reverted my box back to stock using the M8S_PRO+-20170715.093046.V0321-signed.zip in TWRP
        It replaces recovery so be sure and flash the TWRP.img before you reboot.
        This box is still slow and crashes allot, it's barely worth the $40 I paid
        It does run FTMC alright but most apks crash as some point and the box totally freezes too often
          Try a different power supply, must be 5 volts.
            Mines been fine?
              Thanks but do you think this is going to help with google services crashing or the launcher crashing or keep Terrarium from freezing ?
              well they conveniently made the hole smaller than all the other 5v 2a power supplies I have
              T95z / H96 Max plugs are all too big
                Low power causes all kinds of problems, your box should not be crashing, or freezing. That was just something to try if you already have an extra PS.
                  Thanks, I'll have a look at that ...
                    Hi Magendanz,
                    I am not really having major problems, just wondering why I might be getting different results to others. My trouble is I really don't know enough about all this stuff, but I have had some extra fun learning a little. I think I probably got something wrong along the way and need to try a reset and start fresh again.
                    Thanks for all your hard work, much appreciated.
                    Pete
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      When in doubt, a clean flash with factory reset (a.k.a. data wipe) is your friend. My preference is to just flash the Amlogic burn package (.img file) with USB Burning Tool, just like they do at the factory.
                      Hi Magendanz,
                      Pete
                      When I ran into trouble after too much hacking around - i just rebooted into TWRP recovery and did a:
                      Wipe > Swipe to factory Reset
                      and I have had no problems every since
                      • Guest's Avatar
                        Guest commented
                        Editing a comment
                        As long as you're not making changes to the system partition, that should usually work.
                      Just got mine ,and lost no time installing the ota update ... very nice indeed , perfect for me as my non smart plasma tvs are just 1080p
                      Sent from my iPad using Tapatalk
                        I've got the Mecool box, initially I've used the update function to flash 25/8 TV ROM from here, device worked well, was able to install apps, etc.
                        after few days device started freezing, whilst idle, whilst booting, whilst loading, became useless, even froze with Android circles bootlogo screen.
                        Today tried flashing both factory image, and, TV ROM image, though still have probs, at one point, box froze with Mecool blue screen on boot.
                        Have I got a bad one?
                        What options in Burn tool to use?
                        I had:
                        erase flash TICK erase all
                        (force erase??)
                        erase bootloader
                        reset
                        overwrite key NO
                        Thanks for any pointers and suggestions, thanks for the ROM
                        [22:12:38 024][HUB5-4][Inf]--Device is removed
                        [22:12:38 051][HUB5-4][Inf]--[0x00000000]Burning successfully
                        [22:12:38 051][HUB5-4][Inf]--Close device handle 0x000003b8
                        [22:17:43 261][Global][War]--User click stop button
                        [22:17:43 262][Global][Inf]--Enable burning 0
                        M8S_PRO+-NMF26Q-20170815.182813.V0321
                        M8S_PRO+-V0321_TVStock-20170825
                          I have a question about that ROM before I buy Mecool M8S Pro+
                          Will this remote (https://www.geekbuying.com/item/MX3-...es-319093.html) and its microphone work with that ROM?
