From everyone's posts it seems no connection is being made so I'll have to get that squared away.
Originally posted by KBJ55 View PostGot it! I tried it by connecting the cable to the device first and then connecting it to the computer and I think that did the trick. As to why, I don't know, but it worked.
Thanks everyone for your help!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
So, you were able to install this firmware by using the burn tool?
I don't know it this will solve that stuttering problem with the HDHomeRun app although I should know in the next few days as I use the device.
I registered just to say a big Thank You to Magendanz. This firmware has made this box a thousand times better than the original firmware. I've got 2 boxes and flashed the firmware on both. I used the OTA steps however I did a factory reset on my box prior to flashing the firmware. Those that are experiencing issues may not have gone through the proper steps to properly flash the firmware.
Again, thank you for your hard work.
Originally posted by dolarrr View PostWith this rom this box is almost perfect. No lags, Netflix, Youtube, simple games for kids.
Also, when you watch Youtube in fullscreen, does the TOP notification bar auto-hide...or does it always stay on?
Thanks.
Originally posted by legnosecco View Post
I'm not running this ROM yet, can you check what Version number Youtube is under Settings/Apps?
Thanks.
Originally posted by Karce View PostI registered just to say a big Thank You to Magendanz. This firmware has made this box a thousand times better than the original firmware. I've got 2 boxes and flashed the firmware on both. I used the OTA steps however I did a factory reset on my box prior to flashing the firmware. Those that are experiencing issues may not have gone through the proper steps to properly flash the firmware.
Thanks again
Thanks.
Mine is showing ATV YouTube Version 2.00.19
and
there is an Update available in the Play Store 2.01.04
First of all, thanks Magendanz for your hard work on this ROM!
This morning I flashed my M8S Pro+ (S905x) with USB Burn. Worked great, while trying to set it up. But after installing SPMC and FTMC trying to get frame rate switching working, it started to crash and randomly reboot. So I reburned the image to see if I corrupted something. But even on the clean image it would crash and reboot almost instantaniously. (Shortly after showing launcher, crash messages refer to random Android processes).
So just to make sure there is no problem with the hardware I burned the OEM image (M8S_PRO+-NMF26Q-20170815.182813.V0321.img). But still crashes and reboots.
Is it safe to say I'm dealing with a hardware issue?
Thanks!
There might be an issue with the 20170815 OEM firmware release, upon which this custom ROM was also built. Have you tried rolling back to the 20170730 release? (This was available only as an OTA update, so install in TWRP and don't forget to do a Wipe first) https://1drv.ms/u/s!AoqocX31ecnXgZ0C0X-jM77e3x1oyQ
Amazon Prime: thought I'd point out that if you have Amazon Prime, you can install Amazon Webview and Chrome (via Aptoide, in my case), log into Amazon via Chrome, select a show to stream and your reward will be Prime Videos in HD.
NB: be sure to set Chrome to "request desktop site" from its settings. When your video starts to load (spinning circle), let it do so for a bit then click near the top right of the black screen and you'll be able to select full screen video. The stream takes a minute to ramp up, but when it does it can reach 1080p and stay there for the duration.Last edited by Zahir; 14 September 2017, 20:07.
Originally posted by Zahir View PostAmazon Prime: thought I'd point out that if you have Amazon Prime, you can install Amazon Webview and Chrome (via Aptoide, in my case), log into Amazon via Chrome, select a show to stream and your reward will be Prime Videos in HD.
Just confirmed my ATV Netflix 2.00.19 streams in HD and DD5.1
Pete
Originally posted by abbots View PostI've got the Mecool box, initially I've used the update function to flash 25/8 TV ROM from here, device worked well, was able to install apps, etc.
after few days device started freezing, whilst idle, whilst booting, whilst loading, became useless, even froze with Android circles bootlogo screen.
Today tried flashing both factory image, and, TV ROM image, though still have probs, at one point, box froze with Mecool blue screen on boot.
Have I got a bad one?
What options in Burn tool to use?
I had:
erase flash TICK erase all
(force erase??)
erase bootloader
reset
overwrite key NO
Thanks for any pointers and suggestions, thanks for the ROM
[22:12:38 024][HUB5-4][Inf]--Device is removed
[22:12:38 051][HUB5-4][Inf]--[0x00000000]Burning successfully
[22:12:38 051][HUB5-4][Inf]--Close device handle 0x000003b8
[22:17:43 261][Global][War]--User click stop button
[22:17:43 262][Global][Inf]--Enable burning 0
M8S_PRO+-V0321_TVStock-20170825Originally posted by abbots View Postmy Mecool unit worked fine for 1 week with ATV ROM but, now started locking up, even on boot, freezes often (not always) on splash screen or Android dots
tried reflashing with USB BurnTool 2.08 with either M8S_PRO+-NMF26Q-20170815.182813.V0321 or M8S_PRO+-V0321_TVStock-20170825 BUT, on power up keeps freezing
Burn Tool shows OK, no errors
am I doing something wrong ? what else can I do ? have I got a bad unit...?
Just swapped the power adapter for another 5V 2A unit from my other S905 box (running Libreelec). Still crashing.
Any suggestions for things to try, or just bad boxes?
Thanks again
There might be an issue with the 20170815 OEM firmware release, upon which this custom ROM was built. Have you tried rolling back to the 20170730 release? (This was available only as an OTA update, so install in TWRP and don't forget to do a Wipe first) https://1drv.ms/u/s!AoqocX31ecnXgZ0C0X-jM77e3x1oyQ
There are currently 3950 users online. 2 members and 3948 guests.
