Originally posted by Jeffers View Post
Yes you do, it will have less buttons than the one that came with your Mecool.
I bought Meccol because of that,and because we can use a remote(Android TV) instead of a mouse(Android box).
I have used Android boxes for many years.
So if a "fix"isnt coming soon,we will change to Nvidia.
Originally posted by NewbBoxie View PostI'm having the same issue on my MECOOL M8S PRO Plus.
I'm sure a solution will be forthcoming.
After all, these players do have the hardware (Widevine) to enable them to operate with Netflix right?
Originally posted by giok View Postso, there is no way to have working netflix on mecool m8s pro L now?
Hello all,
I made an account on this page because I have the same issue on my M8S Pro W.
I spoke to Netflix and this was their response:
Netflix Mariciris P.
Can you please provide me the model on your device please.
You
It is a Mecool M8S Pro W
Thank you. In this case We thank you for reporting this and we are aware of this issue as of the moment you can use a different device. Since this is a known issue.
You
When you say known issue, is it currently affecting multiple users?
Yes, that is correct and since you mentioned your using a Mecool Device.
You
Is it something that is being fixed, or was it stopped on purpose?
This is actually being investigating and our team is working on it.
You
Ah excellent, that is good to hear!
Hopefully this was the truth and we will have it back soon!
Thanks!
Originally posted by JoseM View Post
Any disadvantages to this vs off the Play Store?
Also, instructions on how to get it installed?
Thanks all.
You
You
You
You
Thanks!
would suggest to contact the manufacturer of the box you have to see if there is any updates that needs to be done.
There are currently 2441 users online. 3 members and 2438 guests.
