    Originally posted by uscool View Post
    When i meant Stable I meant I dont have any issues on mine that it drops off and on , been really solid for me
    its strange then urs never do that and in mine and other people does even who has original nexus and others mecool boxes with this android maybe some fix in future oreo rom or firmware wil fix this, i rememver that the original stock rom the wifi never goes down but that rom is so so ugly without the original playstore or virtual buttons that i have to install this wich is a wonderfull rom just the only bug is this wifi random drops
      My new M8S PRO+ arrived on Friday, and it had a slightly newer firmware release (20171208.183013.V0928). I was able to dump the partitions and create both a signed OTA update and AML burn package:
      M8S_PRO+-ota-20171208.183013.V0928.zip
      M8S_PRO+-NHG47L-20171208.183013.V0928.img
      I'll attempt to update this custom ROM on the new OEM firmware tomorrow.
      Note: The OTA update has my update script, so you can downgrade and install from TWRP.
        Thx
          Amazing
          Thk
            Guest
            Thx for your job.
              Amazing work and much appreciated thank you
                Anything actually changed in the builds ? Compared to the last one?
                  Hi Folks, i´m new to this forum,
                  And first i´d like to thank Magendanz and all the other cracks developing firmware updates for our TV boxes.
                  I have a problem downloading the roms from Magendanz Post#1667. Anytime i get the "Disable Adblock" Site.
                  Of course did i disable my adblock plus, i even tried other browsers without adblock installs, but everytime i get that message instead of the download.
                  Did i miss something?
                  Any help would be apreciated.
                  Case closed :-)
                  I found out that my Kaspersky Anti-Banner was the guilty...
                  By the way i´m on stock rom NMF26Q 20170829.121614.V0321 and my M8S Pro+ is suffering from Wifi-Drops as a few described already.
                  My hope is that the new rom or better the new custom rom version will fix this issue.
                  M8S Pro+
                    Any chance of looking at M8S Pro L anytime soon please?
                      PRO L has his own firmware and it's newer than PRO+
                        just a hint to the owners of users of the "bad batch" devices, that there were some success reports flashing an other alternative software on these devices here:
                          any news on the updated rom for this nifty little device =]
                            True the wifi drops is the major pain in the ass this roms have unfourtnly i cant have my box near router to connect trought cable, so i hope a rom come out soon, to fix this issue that sucks, i never see any movie to the end or iptv because of this major bug and i bet all users of this box have this bug :/
                              Hi Magendanz, I have an Nexbox A95X 2gb/16 gb AP 6330 wifi. I'm currently using the "NEXBOX-A95X_S905X_7.1_bcm6255_6330_16g2g_171120" firmware and I would like to run your TVBOX variant on it.
                              I've been searching here and you said it's not possible to flash this rom on my box. So I was thinking, maybe if I copy over just the system folder and port the build.prop changes over to the Nexbox one and replace on the folder, it would work? Or it's way more complicated than that?
                              I also thought about flashing the Opengapps TVStock-Package on top of the stock rom using TWRP but I'm not sure it would crash the box.
                              Any tips? Thanks for the amazing work on your roms!
                                Hello I am on 20171208.183013.V0928 and I failed to update my M8S PRO Plus to the new custom firmware .
                                Can I use the latest ROM available ?
                                Thanks in advance
