Originally posted by geordieboyo View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by geordieboyo View PostThanks guys.
Have ordered the box - so will probs open the box myself and post a pic.
Just one thing - How do you go about flashing the firmware to one of these out of the box ?
Originally posted by sigdrak View PostI seem to have issue with Widevine and/or some applications using TVStock 20171216. The device was delivered with 20170815.182813.V0321, and it was working (getting HD), although I hadn't tested in a while.
Originally posted by uscool View Post
simple just download OTA UPDATE file and save to usb then load box up and can use OTA updater
I've bought a M8S pro+ from Gearbest and got one with the faulty eMMC. I just did a factory oem update and after not booting up anymore, I've found this forum and the informations about the bad batch.
However, I did a picture of the firmware version which was on the box previously. It was 20171031.091923.V0619. Maybe I can fix it if I put the factory firmware on it with which it was shipped.
Does anyone have it?
Thank you!
edit: This is what I've found but there's not the version of the firmware I'm looking for :/ http://www.mecool.pl/pliki/mecool_m8s_pro+/Last edited by paoblo; 25 February 2018, 22:21.
Hey many thanks for the TV stock variant. But now I have myself a problem. I purchased 2 mecools, one for me and one for my father. The thing is that I updated both to TV Stock variant because I like it a lot and I think is the perfect experience, but my father somehow thinks that the TV Box was fine with version 20171124. The thing is that I searched 20171124 downloaded it, and went to install it but I get error: the firmware model is "p21x"
What can or should I do?
You can pull the "updater-script" file out of META-INF\com\google\android of the zip and edit the line
(file_getprop("/system/build.prop", "ro.product.device") == "M8S_PRO_PLUS")
Change it from "M8S_PRO_PLUS" to "p21x"
Just put the file back into the zip and it should work. You can even take out the platform check but it's easier and faster to just adapt it.
The next time you do a oem update it should work out of the box without editing the updater-script file in the zip. The oem update fixes the build.prop file.
Does anyone have the oem 20171031.091923.V0619 firmware? I've got a box with the faulty eMMC :-/
Originally posted by lezioul View PostDo you think it's possible to add Playready DRM support?
s905x soc should support this, but DRM info suggest the opposite and as far as i know, this is the main reason why we can't play video in Amazon Prime Video Android TV App.
So my M8S Pro Plus box arrived today - https://goo.gl/QRwKW6
Just a couple of things, how do i go about checking to see if this box is ok to flash the firmware ? And if you need to remove the cover, how do you do this? I see no screws on the bottom of the box.
the firmware out of the box is 20170919.150557.V0619 if that helps?
I’ve used a eMMC check app and it says
Type: 016GE2
Date: 06/2014
brick bug? No sane chip
is this enough info to confirm this box is ok to flash this firmware please?Last edited by geordieboyo; 03 March 2018, 21:38.
There are currently 2650 users online. 0 members and 2650 guests.
