Can I ask for some confirmation of the following:- If you have a bad batch box (B3), you must not update the ROM from stock if you want the box to work in Android.
- If the B3 came with OEM rom 20170829.121614.V0321 then even if not updated, the B3 is liable to freeze or be unstable.
- To dual boot the B3 to run LibreElec the rom must be updated to a custom rom.
- If the B3 rom is updated, it cannot be updated again and may be bricked if attempted and dual boot will no longer work.
- If the B3 rom is updated, it will/may not be possible to boot into recovery.
Originally posted by Ozman View PostCan I ask for some confirmation of the following:- If you have a bad batch box (B3), you must not update the ROM from stock if you want the box to work in Android.
To 100% confirm you have a box with problematic Samsung 5.1 eMMC you will have to open the MECOOL up and look for the Chip with:
KLMAG1JENB . B041 . S558Z034
See this post:
http://freaktab.com/forum/tv-player-...473#post673473
From there I would take a Photo and then ask for a refund from whomever you bought the box from stating an OTA Firmware update bricked it. (even if you have not yet reflashed)
If you get to keep the device even better - leave it on the Android Firmware it came with - NEVER reflash it.
Originally posted by Ozman View Post3. To dual boot the B3 to run LibreElec the rom must be updated to a custom rom.
Once LibreELEC Kodi is running from an external micro SDHC card, you can copy the LibreELEC data into internal faster eMMC flash storage if you want. Android will still remain intact and fully functional:
[HOWTO] Boot (LibreELEC) from SD card, use internal memory for data (click)Last edited by wrxtasy; 04 October 2017, 09:48.
Originally posted by wrxtasy View PostCorrect.
To 100% confirm you have a box with problematic Samsung 5.1 eMMC you will have to open ithe MECOOL up and look for the Chip with:
SEC 701 . KLMAG1JENB . B041 . S558Z034
See this post:
well um;ess my soldering sucks or the press button switch doesn't work the new box that i added a reset button too wont boot to recovery via the button :/ guess ill try pulling the box apart again and using a paperclip to short the 2 points that is underneath the board? wont be modding this box untill i can find a hardware way into recovery
No - That is a 5.0 eMMC - the 2 is the easy identifier KLMAG2WEPD
Haven't heard of any 5.0 being faulty ...
Strangely
"2" is 5.0
and later 5.1 is "1"
Could you pls advise me with any tips regarding which method should I use to try to revive my box? Do you think that I could still use this ROM or should I go to the OEM?
Thank you.
If you don't have the KLMAG1JENB - B041 eMMC chipset, you'd be the first to report an affected unit without it. My guess is that you can flash anything you want.
As always, I recommend flashing the whole burn package (.img file) using USB Burning Tool and a male-to-male Type A USB cable, just like they do at the factory. If you're getting to the logo screen, then your bootloader sounds intact and the device should be detected by the WorldCup driver. Just make sure you're only connecting the USB cable, and that you hold the reset button in when you connect it until you hear the PC recognize the device.
Guest so if my emmc is SEC 649 can I install your ROM? Pic rel
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
That's a good question. The earliest lot at this point that has been reported as problematic is SEC 652, which were in production just 3 weeks later. Do you feel lucky?
Seriously, though, I'd give it a try flashing the 20170919.150557.V0619 OEM firmware. If that works, then you're probably fine to flash whatever you like.
my first device can not be updated. So - where to buy a device without Flashing problems ? My "faulty one" is from geekbuying. Or is it like "you´ll never know what you´ll get " ?
EDIT: Just had a livechat with geekbuying and asked which FW Version and eMMC Chip is on the device if I´ll buy a second one now. The answer was complete rubbish
(CPU: S905X Vierkern - Cortex-A9 ) and then the laptop was unusable (something with script does not answer and has to be closed ). This was the end of the chat....Last edited by bylderup; 04 October 2017, 18:05.
Originally posted by mabocoglu View Post
While Mi has a good performance, Mecool is dying on WiFi connection (sometimes drops). Even it is near router.
Hi, I also can agree, that eMMC SEC 652 is not working well.
After Flashing ATV ROM it got stuck at NEXUS logo. Then when I will reflash OEM rom Burning tool aborts in best case at 98% with an error. In the most cases earlier.
Any Ideas how to flash original ROM back? Flashing with SD Card don't work for me?!
I followed your recommendation and I was able to revive the BOX. Thank you! I've updated with your latest version and everything seems to be ok now.
Unfortunately NETFLIX is not loading, it get stuck in a black screen and dont load. Also I haven't figure out a way to make the dualshock 3 to work.
But at least the box is working now!
There are currently 2142 users online. 2 members and 2140 guests.
