Guest
You just need to turn it on in Developer Options. Click the build area 7 time in About to expose that.
Originally posted by DKAngel View PostMagendanz, got both my boxes on latest install nownice work
what else could possibly make this ROM more awesome?
(I used color correction to have a solution but I had to make a factory reset, because device became dead after color correction
Also I have black screen on Netflix. There is nothing on screen and I cannot come back to home via "back" button.
There is another problem, but this one is about my device specific. Sometimes device shut itself down due to the heavy load may be :/
Hi Guys,
Just got one of the lucky one, B041 sec713, version 20170815. Bricked it after ato update. Tried everything except mask rom, didn't work. Went through all the threads this morning. And now problem solved and I even have the tvstock running in the box now.
solution is simple: open usb burning tool, import original 20170815 version IMG, click start, tick force erase, hold reset , plug in usb to computer ONLY (don't connect power!!!), flashing started within 3 seconds.
After checking it did work, I flashed tvstock 0930 version same way without any problem.
Originally posted by mabocoglu View Post
Google Play movies does not show video (only progress bar is shown). You can only hear movie's audio(I used color correction to have a solution but I had to make a factory reset, because device became dead after color correction
Just got a new box delivered from BangGood.
My order was made during the super cheap 11th Aniv. Sale but was delayed shipping - Maybe the bad batch was withdrawn !?
The new box is build Date Code - BB-ROC170825PS
eMMC is Kingston
RAM is 4x matched code (Not just marked D/X)
There is NO RESET Button !!
FW - NHG47L 20170914.183646.V0619
#757.1Guest commented03 October 2017, 23:14Editing a commentYour reset switch is mounted on the top of the PCB facing the front vent (bottom), at lower-left corner in your photo just below the wireless chipset. It's a little awkward to access through the vent, but you can do it with the other end of a paper clip as shown here: http://freaktab.com/node/660688
Got the 701 and didn't see the warning about the bad batch, flashed to the latest ATV. Obviously it didn't go well. I was able to boot to twrp recovery, tried everything but didn't work.
At last resort, I used the burn card program put the original fw on it. Saw a quick flash on my TV screen and the box just shut down. Now the light just stays red, wont turn on by remote or unplug plugging the power cable. So I assume it's bricked then?
Thank you
eMMC is Kingston
FW - V0619
eMMC is Kingston
FW - V0619
Do you think WiFi performance is about Power Supply? I have very bad WiFi connection and I have EU plug adapter. Should I change power adapter and try?
Thank you
Just a bit difficult to find one with the little Yellow 4.0x1.7mm Plug
I had an old TomTom adapter that luckily fits and is good.
There are currently 3139 users online. 1 members and 3138 guests.
