Originally posted by Ozman View PostCan I ask for some confirmation of the following:- If you have a bad batch box (B3), you must not update the ROM from stock if you want the box to work in Android.
- If the B3 came with OEM rom 20170829.121614.V0321 then even if not updated, the B3 is liable to freeze or be unstable.
- To dual boot the B3 to run LibreElec the rom must be updated to a custom rom.
- If the B3 rom is updated, it cannot be updated again and may be bricked if attempted and dual boot will no longer work.
- If the B3 rom is updated, it will/may not be possible to boot into recovery.
Originally posted by bylderup View Postmy first device can not be updated. So - where to buy a device without Flashing problems ? My "faulty one" is from geekbuying. Or is it like "you´ll never know what you´ll get " ?
EDIT: Just had a livechat with geekbuying and asked which FW Version and eMMC Chip is on the device if I´ll buy a second one now. The answer was complete rubbish
(CPU: S905X Vierkern - Cortex-A9 ) and then the laptop was unusable (something with script does not answer and has to be closed ). This was the end of the chat....
Originally posted by driver View PostHi, I also can agree, that eMMC SEC 652 is not working well.
After Flashing ATV ROM it got stuck at NEXUS logo. Then when I will reflash OEM rom Burning tool aborts in best case at 98% with an error. In the most cases earlier.
Any Ideas how to flash original ROM back? Flashing with SD Card don't work for me?!
Guest
Just thought I'd point out that the new V0619 build ID (NHG47L) actually corresponds to Android 7.1.2_r11 with the May 2017 security updates. It's not 7.1.1 as recorded in the OEM build.prop.
And there are features like Dolby Vision support in this ROM that were introduced in Android 7.1.2, so it's definitely the version number that's wrong.
If people are really into some DIY, you can replace the poor SCI WiFi Module with an integrated RTL8723BS SDIO WIFI + BT module for $3 and some soldering skills:
Originally posted by wrxtasy View PostIf people are really into some DIY, you can replace the poor SCI WiFi Module with an integrated RTL8723BS SDIO WIFI + BT module for $3 and some soldering skills:
We can buy separate emmc module from supplier Kingston and replace it in mainboard (PCB-that is the name of mainboard?) ?
Maybe someone sells these modules on aliexpress ;>Last edited by essir; 05 October 2017, 10:28.
Originally posted by essir View Post
I've got an idea....
These are the "pins" / surface pads that have to be de/re-soldered with this surface mount package...
Lots of fun for the adventurous DIY enthusiast
Guys, has anyone tried to install the Nvidia Shield Google Assistant apk on Magendanz's ATV firmware ?
You can find it on apkmirror (https://www.apkmirror.com/apk/google...ease/#whatsnew).
I tried but install fails and I had not yet the opportunity to check the logs...
Do we need any additional driver? Here is a link for driver.
Realtek SDIO Wi-Fi driver. Contribute to hadess/rtl8723bs development by creating an account on GitHub.
Realtek RTL8723BS Wifi Module DataSheet
SCI S9082C WiFİ Module DataSheet
I have checked all GND (Ground) and voltage pin number are equal. Rest of them may be changed due to the bluetooth etc. Therefore, can we say it is compatible?
#851.1Guest commented05 October 2017, 21:47Editing a commentYou'd have to update the kernel and system with the new WiFi kernel modules. Bluetooth, unfortunately, is more complicated and would require a complete rebuild with different precompiler directives. You might actually be better off trying to adapt the M8S Pro L firmware.
Originally posted by mabocoglu View Post
If we change sci wifi with realtek, is it possible to use it with V0619 kernel?
https://www.pine64.pro/download/docu...-bluetooth.pdf
https://fccid.io/2AKCE-S82GESNC/User...al-3209392.pdf
Here is v1.2 version
Here is v1.3 version
https://www.aliexpress.com/item/RTL8...495116310.html
Also we will need a bluetooth antenna (or not?)
Finally, will it worth?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Rafaluke View Post
Hello Magendanz!
I followed your recommendation and I was able to revive the BOX. Thank you! I've updated with your latest version and everything seems to be ok now.
Unfortunately NETFLIX is not loading, it get stuck in a black screen and dont load. Also I haven't figure out a way to make the dualshock 3 to work.
But at least the box is working now!
In your previous version (20170825) Netflix was running fine. Only with the latest that is not. Don't know what could be the issue... tried to uninstall and install again from the store and nothing. The app install normally, but when you try to open, it goes to black screen. It not freeze the BOX, since I can go to the home screen with the remote... but the app dont run.
Maybe I could try an older version of the Netflix app, but I dont know where to find older versions for Android TV.
Regarding the PS3 controller apparently it is more hard than I was thinking!Do you know if PS4 or XBOX ONE controllers would work?
THank you again!
Hello Magendanz! Thank you for your reply.
THank you again!
There are currently 2736 users online. 1 members and 2735 guests.
