You can see and compare on the link below:
maybe the Solution is to soldered 2 pins in NAND chip http://freaktab.com/forum/main-categ...short-location
Hello. First I would like to give congratulations for this great ROM! Really good job.
I have just one issue. The Google Play Store store is not working properly. When I access it, it appears only a very few apps for download, not the complete list of apps. Do you know any way to overcome this issue, in order to access the "real" google app store?
Thank you.
Guest
So, if you're familiar with the BrickBug issue, you'll realize that this isn't the first time that Samsung eMMC controllers have had problems.
https://forum.xda-developers.com/sho...php?p=27074278
https://forum.xda-developers.com/sho....php?t=1693704
https://www.xda-developers.com/deter...-got-brickbug/
https://www.xda-developers.com/anoth...ous-brick-bug/
If what we're seeing is a related issue, the problem may also be that we've discovered another defective eMMC chip/fwrev that's unable to handle MMC_CAP_ERASE commands (command 38) properly.
Have people tried completely unchecking "Erase flash" and "Erase bootloader" when flashing ROMs in USB Burning Tool?
Also, has anyone had better luck flashing from Mask ROM mode? In theory, this would be closer to the conditions it would see on first flash at the factory.
Ref Mask ROM mode.
This is best -
... Thanks Magendanz
Load the image in USB Burning Tool and hit Start
Connect only the USB OTG cable
Short the pins on the eMMC
"Connected" noise
Flash starts automatically
Pins-Z69 (Same as M8S Pro+?)
Is this the correct method - Answer = No (See Magendanz comment)
Launch USB Burn Tool
Short 2 Pins on reverse side of PCB
? Press-Hold Reset Button
Connect Comp USB A-A
Wait - Recognised-Connected
Remove Short
? Release Reset
May need 3 hands ???
1 comment
#698.1
Magendanz commented
10-02-2017, 20:06
I actually find it's easier to load the image in USB Burning Tool and hit Start, connect only the USB OTG cable, and then short the pins on the eMMC. As soon as you get the right ones, you'll hear the sound from your PC as the WorldCup driver recognizes the device and the flash will start automatically.
To attempt a Mask ROM mode flash, am I correct that you keep pins shorted during the entire flash with USB Burning Tool? If this does allow for successful recovery, I guess the solution on the affected boxes is to solder a small switch on the pins to short when ROM update desired.
Originally posted by essir View Post
ready any progress? I have the same mainboard like kml and you.
https://imgur.com/a/8j9dw
But recovery does not see any files on sdcard. I do not know where is the problem?
Originally posted by Magendanz View PostSo, if you're familiar with the BrickBug issue, you'll realize that this isn't the first time that Samsung eMMC controllers have had problems.
Also, has anyone had better luck flashing from Mask ROM mode? In theory, this would be closer to the conditions it would see on first flash at the factory.Last edited by anthony96; 02 October 2017, 20:29.
Originally posted by kml View PostTo all unlucky SEC701 owners!
I have that chip inside my box. I've flashed it with ATV just after arrival - without checking the installed firmware. That caused a lot of frustration and hangs. After checking almost all available firmwares, I have one that is rock-solid: M8S_PRO+-20170829.121614.V0321!
Flashed by: Burn_Card_Maker, all options ticked (erase in force). Filename changed to: m8s.img, card size: 8GB.
I can't say I'm happy, because that official firmware is a crap (I can't sort the 5.1 sound from Netflix, etc.), but the box works without any problems. I'll be happy to see an ATV solution
I used the Burn_Card_Maker with pendrive, becuase it was not working with sdcard.
Originally posted by Rafaluke View PostHello. First I would like to give congratulations for this great ROM! Really good job.
Thank you.
When is related to video apps, Netflix, Youtube and KODI provides every needs for sure, and then the ROM is GREAT. But I was also wondering if I could still play some android/emulation games in this BOX. Do you know if, since is an Android TV build, I will have issues to play games?
Also I was trying to use a cabled PS3 dualshock3 controller and no lucky so far. Can this be related to the Android TV build, or maybe is just me!?
Thanks.
There are currently 1916 users online. 0 members and 1916 guests.
