Originally posted by P.X View PostI think Gearbest the least likely to have access to 08.29 FW - It might be worth asking GeekBuying ? Does Trebor have a direct line by any chance ??
Others have had boxes from a supplier other than Gearbest with same FW and issue.
Originally posted by grimmie View Post
the img file that magedanz made from your dump is already the same right? why need ask from gearbest?
ready probably wants a full original version to try, I think ...
(Answered above while typing)
Originally posted by ready View Post
If you ordered from Gearbest, pls ask them for this FW (20170829.121614.V0321) - especially that they told you to change it to the higher version.
I can't really ask GearBest as I have had a full refund already and my ticket is closed.
Updated my good box to the latest V06xx ATV (Beta?) using USB Burn Tool
-Erase Flash>Force Erase
-Erase Bootloader
2' 50" to 98% (verification point)
3' 30" to 100%
About 3 minutes of Swirly ANDROID Splash Screen and then the super easy ATV Setup.
Looks great and I managed to restore (manually) all my apps using Android Assistant
Working nicely so far ....
What was that about a working something bar ? in this base build, the thing that allows VPNs ??
Can't see anything ?
Pete
p.s. Still can't find a way to set UK Keyboard layout for my Rii ?
-Erase Bootloader
3' 30" to 100%
Pete
p.s. Still can't find a way to set UK Keyboard layout for my Rii ?Last edited by ready; 30 September 2017, 20:11.
Here are some comments about ATV 20170919.150557.V0619
First of all thank Magendanz for preparing this ATV rom image.
It is the most stable version I have ever seen for this device. I use this TV Box on Samsung 4K TV (60hz)
Crashes and freezes on previous rom are not about CPU temperature as I said before. They were software bugs or driver for Android, I don't know.
There are some bugs or problems about this image.
When I want to watch something on Google Movies, I can only hear the sound, there is no screen (video)
I have a black screen when I open Netflix.
Android Remote service does not work very well. Cetus Play is the best solution for Android TV. It has even iOS app and you can install many apps from remote.
Google Cast receiver is not working and Magendanz told me about that.
Initial setup (Google account and wifi setup) sometimes crashes. You may have to set it up more than one. If you succeeded, then everything becomes better.
These are I remembered. Whenever an app crashed, you don't loose your TV Box, You can always can go to the home screen.
The one that I like most is the Youtube receiver. It runs perfectly.
Also,
I liked to have a Power option next to the App Drawer on home screen. It was absent on this rom. It should have international language support. Even it has not, it was nice on home screen.
I want to as Magendanz to prepare a new ROM which includes opengapps latest release (30 September). It may be fixes about theese problems (at least no video screen on Google Movies).
I have tried by factory reset, but that did not help.
Does anybody has no video on Google Movies app?
Thank you.
Guest
Originally posted by essir View PostI don't think so that banggood or gearbest will agree somekind of "field claim". Off course if it is not a hardware problem. It seems to me that every person who update wrong software in meaning of this store was broken the warranty rules.
The only hope for me and us is Magendaz (ROM developer) ... and maybe he find solution.
Note that I've also added a BIG RED WARNING to the OP on both my M8S Pro+ custom ROM topics.
Originally posted by Magendanz View PostBoth superceleron and I are convinced that these problems stem from a bad batch of eMMC 5.1 chips, as evidenced by the fact that the problem only affects specific factory runs shipped in August which also fail on OEM firmware and even LibreELEC (although less frequently when run from the SD card). No firmware update is going to be able to solve that.
There are currently 2159 users online. 1 members and 2158 guests.
