It is fixed after I have done a factory reset. Now I get an error when I try to open Google cast from AppDrawer. Also this rom made device very slow.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by mabocoglu; 30 September 2017, 00:05.
Well, that one is actually expected. We've been trying to get Google Cast working forever. In fact, I was hopeful when I saw it in the Settings for this OEM firmware release, but it seems VideoStrong has got the same problems as us.
As for performance, Google's Android TV Launcher is going to be a bit more overhead than the VSLauncher, but I've found this firmware release to be surprisingly fast. At least in part, they did this by cheating. VideoStrong removed the window and transition animations, then dialed up the animator scale to double speed...just to make the build feel faster.
Now, it just seems like this build had one too many shots of espresso.Last edited by Guest; 30 September 2017, 00:28.
Originally posted by P.X View PostNo one, as far as I can remember, has Flashed a box that came with 08.29 FW and got a working box. No one has got a working box back by reverting to 08.29
All the boxes, as far as I can tell have eMMC Rev 5.1
Do they all have D/X Ram ?
It would be good to have as much info to correlate as possible, so if all who can could post as asked over in OEM Thread that would be great.
Pete
Note:
KLMAG2WEPD = 5.0
KLMAG1JENB = 5.1
Cut and Paste to OEM thread
If as many as can, could post their
FreaktabHandle - Box ##
STATE = Good | BAD
FW DATE = YYYY.MM.DD
SUPPLIER = Fullname
eMMC Marking = SAMSUNG | SEC
eMMC Rev = 5.0 | 5.1
3 Digit NUMBER = ###
RAM = D/G | 10DIGIT
enjoying more of LE now not jumping to atv yet.
I kind of suspect that the problem occurred when the first flash to 20170815 occur.
Then when that flash happened, even later reflashing it to 20170919 it didn't help.
Getting back to 20170829 got me back to the starting point again and is good. I think moving to 20170919 now would work; but I will wait for Magedanz' work over the weekend and try that.Last edited by grimmie; 30 September 2017, 05:41.
Hi all,
I think I have got a little lost with all the posts and different versions that have been referenced that I'm not sure exactly what I can with my unit.
I only got it yesterday from Banggood and looking in the settings I see that my build version is:
M85 Pro+userdebug 7.1.1 NMF26Q
20170815.182813.V0321
I connected the unit up and played around with the menus, played a video file and all is good so far.
Is my unit one that can be upgraded? If it is one that can upgraded should I use the detail from the very first post in this thread or is one of the images referenced somewhere else on the thread where I should be looking?
To avoid me bricking the device any guidance from the experts on the forum would be appreciated.
Cheers
Cheers
Originally posted by anthony96 View PostSee magendanz comment to my post above, I'm having the same problem. You probably have the same board as mine.Magendanz commented
09-29-2017, 14:16
It's failing in the verify step, which points to an eMMC failure.
Is someone able to organize the OEM FW 20170829.121614.V0321 from Gearbest?
Originally posted by ready View Post
Is there any solution?
It seems to me that every person who update wrong software in meaning of this store was broken the warranty rules.
The only hope for me and us is Magendaz (ROM developer) ... and maybe he find solution.
If you have time to explain it nicely to the gearbest service, please try ... maybe, mecool chinese developers will tell us how to fix it and provide simple turtorial.
Originally posted by essir View Post
I don't think so that banggood or gearbest will agree somekind of "field claim". Off course if it is not a hardware problem.
Originally posted by grimmie View Post
I must be the odd one. Am thankful to magedanz for the stock 20170829 img
Originally posted by P.X View PostGearbest CS told me to flash the original OEM update FW onto my faulty 08.29 box and this bricked my box. They may still be giving the same advice if you tell them it is faulty on arrival, as it is.
I already did it with Banggood.
There are currently 1413 users online. 1 members and 1412 guests.
