Originally posted by grimmie
If you're into movies/tv series, better get LE+Kodi on the box. 1/8 would be no problem I reckon. But you will need an investment of Class 10 micro sd card. Amazon sells one for $12.
Sent from my E6633 using Tapatalk
1 comment
#554.1
Magendanz commented
09-29-2017, 00:11
I don't really see much of a point in doing that, given that I've already made the ATV for 20170919.150557.V0619 and it fixes a lot of longstanding issues. It might be the last OEM firmware that can have TWRP recovery installed, but I wonder how many actually use that.
#560.1Guest commented29 September 2017, 09:53Editing a commentNow that we have an .img file for the 20170829.121614.V0321 OEM firmware, you can always roll back. I'll work on the OTA update over the weekend, but without TWRP now we're hunting for a good local OTAUpdate app. What MECOOL has is butt ugly, and we don't need the OTA option because we're not hosting an OTA server.
1 comment-
#560.1
Magendanz commented
09-29-2017, 00:53
Originally posted by Magendanz View PostSo, with a slightly more awkward process I was able to create the following:
Nexus TVStock variant: M8S_PRO+-V0619_TVStock-20170928.img
Despite my inability to install TWRP recovery, I really like this V0619 ROM. It's fast, plays 4K@60fps in KODI smoothly, has a nicely laid out Settings menu with all the functions you need. Best of all, they've fixed the longstanding problem with the Action Bar on Android TV, so you can access features like VPN.
I'm holding off on an official update until I can really understand what's going on with TWRP and boot verification, but thought I'd share here for folks who don't care about that stuff.
or other person of vast knowledge ...
Probably a stupid question, but is there a way to update my current ATV install (Good Box July Vintage) to this new V0619 version and still keep my installed apps ?
Cheers,
Pete
If you're already on my TVStock variant, you should be able to upgrade to the latest release with an OTA update in TWRP. (I just haven't created that yet.) Just keep in mind that you won't have TWRP in the new ROM, and so you'll need to use the burn package (.img file) to go back. There might be a workaround if I can find a good installable OTAUpdate app.
Originally posted by ready View Post
I have 20170829.121614.V0321, so should I install ATV for 20170919.150557.V0619? Can you please prepare the OTA update for this?
Make sure you check function thoroughly with the OEM FW as delivered, before flashing any other FW - Any freezes then beware !!
All the boxes I have seen mentioned with 2017.08.29 FW are borked by any FW Flashing (at least so far as I am aware)
Originally posted by ready View PostAmlogic USB does not see the device. The driver was installed.
I push the reset button during connecting usb cable.
Originally posted by ready View PostUnfortunately I can not use the img, because my device is not recognized. I installed the usb drives - but it does not work.
Originally posted by anthony96 View PostMagendanz,
I just received mine with 20170829.121614.V0321 firmware, here's the link to the firmware duump https://mega.nz/#!ULI20bQK!BB_knxnfh...RgTFsl6qnpA6rI
Android human with the sign of the cross
Maybe I'm using the wrong program settings...
option 1 -> tested -> Android human with the sign of the cross
option 2 - tested -> without erase bootloader after boot i see green screen and blue light was turn on...
Gents.... what do you think about it?
all possibile options in screen below...
which should I set?Last edited by essir; 29 September 2017, 16:16.
Magendanz commented
09-29-2017, 00:53
As far as I remember i HAD a functional device with original M8S_PRO+-20170829.121614.V03 21 firmware
1) OTA UPDATE TVStock Nexus ROM (20170825) from first post resulted in showing the Nexus logo on startup, but nothing more
2) BURN PACKAGE TVStock Nexus ROM (20170825) with BootcardMaker v2.0.0.2 got stuck with Android logo and a red cross (same for OEM firmware (20170815.182813.V0321))
3) using Amlogic USB Burning Tool v2.0.8 with the above images and the new M8S_PRO+-20170919.150557.V0619.img failed with [0x10303004] or [0x139f0902] error codes
Now, I was hoping to get back with the M8S_PRO+-V0619_TVStock-20170928.img provided in few posts above by Magendanz to a functional device. Unfortunately I also get the same error codes withe the Burning Tool with this image.
Did anybody with a bricked "newer" device succeed to get back a functional box?
There are currently 2395 users online. 1 members and 2394 guests.
