Another question that I have. Is Netflix HD working properly on last build?
Originally posted by leonkoum View PostPlease help...
I manage to establish communication with my faulty box with samsung eMMC but now i have another problem..
The procedure is stuck at 98%
What i am doing wrong?
Any help?
- Erase Flash>Force Erase (?All)
- Erase Bootloader
May not need the Erase Bootloader - Expert may confirm exactly what is required - I was just experimenting.
Even when a flash worked my box never did - It was always faulty from inception.
Originally posted by ready View PostGuest
I managed to restore with Burn_Card_Maker the original FW M8S_PRO+-20170829.121614.V0321 [Box with SEC 701].
What do you think? Should I try and install with Burn_Card_Maker the latest ATV rom on this box?Magendanz commented
10-02-2017, 12:08
You can try, but I don't think the eMMC will take anything other than what was burned at the factory. Anything else (OEM or custom ROM), seems to result in a partial flash.
No, I think those with bad eMMC chips are locked into the factory ROM at this point. The devices don't seem to be able to accept anything more than a partial flash, leaving portions unmodified. Unless you're flashing the original factory ROM, that's just not going to work.
That's really the only hypothesis that I can propose for why only this one firmware revision works on the affected boxes.
Originally posted by ready View PostIs ATV realistic in near future for this box M8S_PRO+-20170829.121614.V0321 [SEC 701]?
#710.1
Magendanz commented
10-02-2017, 12:23
With which FW should I now buy the new box to use it with ATV?
HI Magendanz, when you mentioned adding game controller support for the M8S Pro+, does that mean it will support Bluetooth USB dongle?
Sadly, no. superceleron tells me that there are compiler directives required to build a ROM with Bluetooth support, and to the best of our knowledge only ODROID has managed to create an Android build that can discover and use Bluetooth dongles. It's not just a matter of including the right kernel modules. You'd need to recompile from source.
Guest , so if I have a box with SEC 713, I just should stick to factory ROM? I will request a full refund soon and I'll select, that I didn't get the package (I chose untracked shipping). But could someone tell me, where should I buy that box to get new Kingston EMMC? Because there's no problems with those EMMC, right? And I will be able to flash ATV on it then, right?
+ Tell me, how can I even flash this box? Do I need sd card or some kind of special to connect it to PC? I didn't prepare properly for it, if I would even get box with right EMMC
Guest
Just FYI, I was finally able to compile a build of TWRP recovery that works with the new M8S Pro+ V0619 kernel. I'm uploading the new release now.
Guest
Changelog (20171001):- Finally compiled a build of TWRP recovery that works with the new V0619 kernel
- Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
- TVStock Variant: BURN PACKAGE (972MB), OTA UPDATE (514MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Magendanz View PostChangelog (20171001):- Finally compiled a build of TWRP recovery that works with the new V0619 kernel
Download:- TVStock Variant: BURN PACKAGE (972MB), OTA UPDATE (514MB ZIP file)
There are currently 2564 users online. 0 members and 2564 guests.
