    So, I tried below command using terminal & su:
    insmod /system/lib/modules/hid-sony.ko
    But it failed because no such file or directory, although I can see just before I hit tab command insmod /system/lib/modules/hid.. & then it shows there are 3 options: hid-dr.ko, hid-ps3remote.ko & hid-sony.ko
    How about that?
    Btw, I just notice that when I power off tv, the box will follow to poweroff itself and I have to restart. FYI, I am dual booting with libreelec, so when my box power on it will load libreelec and then to enter android I need to reboot from internal..
    • Guest's Avatar
      Guest commented
      Editing a comment
      If you type "dmesg" after the insmod, you'll see from the logs that it actually isn't a missing file, but unknown symbols...basically a missing library. Most likely this is because it's running in an unfamiliar environment...Nougat. So, I need to find newer versions of these kernel modules.
      Unfortunately, my usual repositories for these (Nexus Player, NVIDIA Shield TV, Xiaomi Mi Box) all have their own dedicated game controllers, and so including drivers for PS3 and generic controllers hasn't been a priority for them. They want to sell their own hardware accessories.
    1 comment
    • Magendanz
      #795.1
      Magendanz commented
      10-03-2017, 23:52
      Ah, you're right. Can't believe they completely removed it. Wow! Can I assume we've checked the M8S Pro location, underneath the pin hole?
    • Nothing there either just the empty holes for a Switch (K1 I think ?? - I've screwed it back together)
    • Guest's Avatar
      Guest commented
      Editing a comment
      Could you post a photo of the underside of the PCB?
    OK thanks for the explaination.
    And what about power tv off will shutdown the box, is it normal?
    Is there any issue, because I have change powerkey definition to shutdown & standby, both will not effected the behaviour..
    • Guest's Avatar
      Guest commented
      Editing a comment
      No, that's definitely a bug. Happens in the OEM firmware too.
    PCB Board revision still the same as unit i first received In July
      Yep, same board, they have just stopped soldering the front facing switch in place.
      Kingston eMMC must be pin compatible I guess.
        That sucks.
          Turn off HDMI CEC
            1 comment
            Magendanz
            #797.1
            Magendanz commented
            10-04-2017, 00:34
            Looks the same as Trebor's pic in his review.
            I can unscrew it tomorrow and take a pic if you really want to see my box's bottom !
            I was only looking at it from the point of view of checking for a reset switch of course ....
            • Guest's Avatar
              Guest commented
              Editing a comment
              Now doesn't that just sound dirty. ;-)
              No, I trust that it's probably the same. We devs were discussing offline and some were curious.
            • trebor
              trebor commented
              Editing a comment
              Sounds wrong yes but anyways ;-)
              Just to be sure if you can.
            Just noticed that Trebor's early July review box (170710 review date - No build sticker) has a 5.1 eMMC while my later August arrival (170819) has a 5.0 version eMMC (Build date 170703)
            Maybe I was lucky to get an old stock chip as Trebor's must surely have been built before my box.
              Just remembered someone asked about removing the SOC Heatsink ...
              I just twisted it of - A bit off carefully applied brute ignorance - It is held with what looks like a blob of silicone mastic type thermal glue.
                2 comments
                Magendanz
                #803.1
                Magendanz commented
                10-04-2017, 01:00
                trebor
                #803.2
                trebor commented
                10-04-2017, 01:13
                Sorry, I just couldn't resist
                Will do ...........
                  They're probably trying to eliminate methods of getting into recovery.
                    Tweakers connecting USB A-A and doing naughty things !
                      HI, I have the M8S_PRO+-V0321_TVStock-20170825 installed. I wanted to update so I tried reboot recovery in the terminal which failed in that the box rebooted but the TV received no signal, just a blank screen. So I tried to boot into recovery by pressing the reset button and plugging in the power. Same result. I am wondering if the rom I have has wiped stock recovery and TWRP. Am I stuck?
                        Turn off HDMI CEC
                        I haven't tried that but I prefer using my TV remote as HDMI cec working well.
                        I'll try that later when I get home. Thx.
