Originally posted by t0x1c View Postdo some one now which hole/pad is for reset and could make a Picture and could point out the pads? (got a Box with Kingston, with no Reset button)
Front right of board next to eMMC is k12 - Four pads - Short Front L to R
http://freaktab.com/forum/tv-player-...900#post675900
Guest
Just FYI, I did another rolling update this evening to address the following minor issues:- Set boot animation speed back to standard (not sure why VS messed with that)
- Set Android version number to correctly match the build ID (NHG47L => 7.1.2)
- Fixed preinstall script to stop overriding the 12/24 hr clock setting
If the current factory build is running ATV with a custom launcher, could the end user go to Play Store, install Android TV launcher and use that as default? For people who are stuck on factory firmware at least that might be a better option.Last edited by silicon; 06 October 2017, 16:05.
Originally posted by Magendanz View PostJust FYI, I did another rolling update this evening to address the following minor issues:- Set boot animation speed back to standard (not sure why VS messed with that)
There's no formal update notice for these rolling fixes. You just need to refresh your download. For most users, they're not even worth mentioning, but you could elect to do a quick OTA update in TWRP and no data wipe would be needed.
it possible to added a Physical keyboards for french et other language please. Thank.
Originally posted by mabocoglu View Post
There is newer chip version (v1.3). But aliexpress is selling v1.0 version.
Here is v1.2 version
Here is v1.3 version
https://www.aliexpress.com/item/RTL8...495116310.html
Also we will need a bluetooth antenna (or not?)
Finally, will it worth?
Bluetooth does not work. In mecool android - no bluetooth menu, in LE if I enable bluetooth and going to bluetooth menu, it says that no adapter found.
Pulled that module, and soldered to a Tanix TX3 mini (instead of another sh.tty sci module). There is rtl8723bs driver in that tanix android, wifi works, but no bluetooth menu. In LE wifi works, bluetooth no, the same adapter not found message.
Wifi and BT antenna is the same pin, same antenna.
Originally posted by Upo View Post
I swapped with RTL module 1.0, but in android no wifi. It was 0619 or 0629 something rom. LE from sd card works, wifi is connecting, all good.
Magendanz commented such a note. Thank you for sharing the results.
Magendanz commented
10-05-2017, 12:47
You'd have to update the kernel and system with the new WiFi kernel modules. Bluetooth, unfortunately, is more complicated and would require a complete rebuild with different precompiler directives. You might actually be better off trying to adapt the M8S Pro L firmware.
Originally posted by pawnthep View PostDue to dynamic refresh rate problem with SPMC/Kodi, I have to change refresh rate manually to match Live TV (50hz) and Movies (24hz).
Is there a command to change display refresh rate to 50hz, 60hz, 24hz without going to the Settings/Display/Screen resolution? If this is possible maybe there is a way to run script with keymap in SPMC to change to the desired refresh rate.
Originally posted by bylderup View Postmy first device can not be updated. So - where to buy a device without Flashing problems ? My "faulty one" is from geekbuying. Or is it like "you´ll never know what you´ll get " ?
EDIT: Just had a livechat with geekbuying and asked which FW Version and eMMC Chip is on the device if I´ll buy a second one now. The answer was complete rubbish
(CPU: S905X Vierkern - Cortex-A9 ) and then the laptop was unusable (something with script does not answer and has to be closed ). This was the end of the chat....
Sh*t... not great if you're living on a Caribbean island and have to get stuff in when friends happen to drop by... ie no easy exchange possible :-(
Ordered box just a day or two before the whole eMMC chip stuff came to light, hoped I got away with it when Iooked at firmware version.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by Rafaluke View Post
Hello Magendanz! Thank you for your reply.
In your previous version (20170825) Netflix was running fine. Only with the latest that is not. Don't know what could be the issue... tried to uninstall and install again from the store and nothing. The app install normally, but when you try to open, it goes to black screen. It not freeze the BOX, since I can go to the home screen with the remote... but the app dont run.
Maybe I could try an older version of the Netflix app, but I dont know where to find older versions for Android TV.
Regarding the PS3 controller apparently it is more hard than I was thinking!Do you know if PS4 or XBOX ONE controllers would work?
THank you again!
I will try to do as suggested:
1st - Factory reset.
2nd - Start Netflix app first or stop other apps
I will report later the results.
Regarding the PS4/XONE controllers, any ideas if it works?
Thanks.
Originally posted by Magendanz View PostI've added the SEC 652 to the BIG RED WARNING. Sorry you had to be the one to make it official. :-(
It's been my experience that the Mask ROM mode reset is pretty reliable, so you should be able to restore your 20170829.121614.V0321 OEM firmware.
Update on the reflashing the original firmware .img file that I downloaded from here - doing a flash in Mask ROM mode isn't working either. The process gets to 98% and the infamous "[0x30405004]UBOOT/Partition system/Verify patition/Error result" message. A couple of things of note, though:
1) Tried USB Burning Tool (UBT) 2.0.5, 2.07, 2.0.8 and 2.0.9, have same results with all.
2) The light on the box is red/blue. If I start UBT then short the NAND pins 14 & 15 (I referenced the Z69 pic) and plug in the USB cable, the PC dings in Windows and the flash starts. However, if I plug in the USB cable without shorting the pins, the PC also recognizes the box and UBT starts the flash process.
3) Tried flashing with the power plugged in to see if having enough power would make a difference; it didn't.
Question for Magendanz: does the 20170829 .img file you posted here have the UBOOT from the OEM 20170829 firmware? You'd mentioned earlier building that .img with UBOOT from other sources. Also, best I can tell Mecool never released the 20170829 software - which is odd considering they've released all those other ones.
Thanks!
If it ain't broke, don't fix it, right? However, take a look at the release notes to the 20171001 build. The V0619 update was significant, in that it upgraded from Android 7.1.1 to 7.1.2, included May 2017 security updates, and fixed some serious bugs that prevented access to More Settings and made buttons and menu items in the action bar disappear. Subjectively, it also feels much faster.
Hello!!
Thanks.
Finish the tests. Factory reset, only one app installed --> NETFLIX.
Tried to run NETFLIX and only black screen.
Tried after run youtube and worked fine.
Tried after run Google Play (Movies) and only play the sound... no picture of the movies.
Any ideas?
Thanks!
Originally posted by KBJ55 View Post
If I'm running 20170815.182813.V0321 and there doesn't seem to be any apparent problems is there any real need to update the box with your most recent ROM?
Thanks!
#883.1
Magendanz commented
10-06-2017, 11:46
That's my usual approach! But it does sound as if it might be worthwhile to update anyway, thanks!
There are currently 2857 users online. 0 members and 2857 guests.
