Hi Magendanz,
Thanks for your work on this ROM, it really makes this box much better.
At one stage I had my box stuck on the Nexus logo. As I didn't have a usb cable I was trying to flash using the bootcardmaker, but was just getting an Android with a red circle with an X no matter which ROM I tried.
I found a solution in this thread, which was to change the name of the .img file to something simpler.
It might help some people if you add a line to the "Notes" section of your first post along the lines of:
If the BootCardMaker finishes successfully but the box won't boot, try changing the .img file name to something short like m8s.img and create the card again.
Ben
Originally posted by Magendanz View PostI posted this on the Stock and Nano thread, but I'll repost here...
If you experienced a hang at the logo screen, you might try refreshing your download for the OTA update. I made some tweaks to the updater script late Monday night, providing more user-friendly environment checks, fixing an innocuous result ("Unknown error []"), and substituting a new package_extract_file() syntax that I found the OEM using in their script. When they switched to the new updater binary, they could have deprecated the old method that I'd been using, which might explain why logo, boot and recovery partitions wouldn't get updated. (These updater binaries are notorious for failing silently.)
Or even better (and always recommended, if you have the cable), flash the burn package with USB Burning Tool.
Some good news for those with the Bad Batch Box. I used Bootcard maker to install the latest ROM from page 1, (October 1). Installed fine via paperclip method.
(1) I can now reboot into TWRP but I'm stumped how I enter commands from the first screen. The remote is unresponsive as is a usb keyboard. As the TV monitor is not a touchscreen, I don't know what to do next.
(2) I inserted my LibreElec used previously with this ROM (Sept version) but it didn't boot with the 1 October rom. Do I need to do anything extra to activate dual boot?
Originally posted by Ozman View PostSome good news for those with the Bad Batch Box. I used Bootcard maker to install the latest ROM from page 1, (October 1). Installed fine via paperclip method.
Also, so is ATV working fine on your box? Can you remind us again which firmware yours came with, and what EMMC chips it has?
Originally posted by KBJ55 View Post
If I'm running 20170815.182813.V0321 and there doesn't seem to be any apparent problems is there any real need to update the box with your most recent ROM?
Thanks!
You may have one with problematic 5.1 Samsung eMMC (see post #1) which means you are going to be stuck on the Firmware you currently use. - forever.
So no bug fixes for you in the future.
If that is the case consider getting a refund from the seller - because you WILL run into problems going forward.
There is no point even trying to fix these problematic eMMC boxes - to everyone - GET A REFUND !
Originally posted by Sossy View Post
Maybe a USB mouse?
(2) Details of my box are at http://freaktab.com/forum/tv-player-...594#post675594
I am pleased to report that I have flashed the 20171001 to my device (that has the bad-batch chips) using the NAND mask Rom method.
I have a box that had 20170815 firmware originally with the SEC713 chips.
It was bricked trying to do an ATV install using the OTA method, I was then able to restore to original firmware using the NAND mask ROM method
As per below, I then tried installing the ATV ROM using the NAND mask ROM method.
This box is now happily running ATV, even though I thought it never could. I have been testing it for the past half hour, running Netflix, Youtube, Kodi, Google Play and messing around with the settings.
It is ROCK SOLID so far!!
I couldnt be happier, and hopefully this gives someone else hope that the boxes with the bad batch of EMMC's can be salvaged
Note, method for NAND mask ROM is below, and attached is a photo of the pins that need to be shorted on the back of the PCB board
From 2nd October...
Hi Magendanz. Do you still think it would be worth trying to flash an ATV rom onto the defective chips, using the Mask ROM method?
If you think there is some chance it may work differently to the burning tool, I might be willing to try it on my box
I am keen to get ATV working, and if I cant use my current box, I will just get another one anyway
#749.1
Magendanz commented
10-03-2017, 03:24
Any time you short pins it's not without risk, so I appreciate you volunteering, Sossy. You'll need to queue up M8S_PRO+-V0619_TVStock-20171001.img in USB Burning Tool and hit Start. Then, with the back of the board exposed, connect the USB OTG cable. Finally, you'll need to short the pins highlighted in my diagram so that you hear the WorldCup driver recognize the device in Mask ROM mode and the flash should start automatically.
My hope is that the flash in Mask ROM mode will model closer what occurred in the factory, since that's the version that was successfully baked into the device even with the
Originally posted by Sossy View PostI am pleased to report that I have flashed the 20171001 to my device (that has the bad-batch chips) using the NAND mask Rom method.
From 2nd October...
#749.1
Magendanz commented
10-03-2017, 03:24
I also wanted to ask if it's possible for me to install xposed installer on this ATV ROM version or the Stock Nexus ROM?Last edited by tantrums; 07 October 2017, 09:08.
Hi everyone,
today i got my M8S fom Banggood with 2017.0914.183646.V0619 FW. I pressume that is not faulty box with Samsung eMMC. I´m little confused because reset button is missing. Is there any way to start Libreelec from SD card? Can i flash Magendanz FW as local update through updater app with OTA update zip file from post #1? What´my options with that box?
Thanks in advance.Last edited by dstojic; 07 October 2017, 16:27.
Yes, you should be fine as these new boxes without the reset switch all have had Kingston eMMC chipsets.
As for flashing, using the preferred burn packages with USB Burning Tool is now problematic, unless you want to open the case and short the PCB contacts where the switch used to be. You can do OTA updates, but please remember to do a data wipe (factory reset). This is especially important when first installing the custom ROM.
Having a (more) interesting issue with my SEC 652 box - I apparently can't get into NAND mask ROM mode. As soon as I plug the USB cable in, the flash process starts in the USB Burning Tool - regardless of whether the pins are shorted.
If I put a micro SD card in, the same thing happens - it attempts the firmware update even without pressing the reset buttton while powering on. It also wont boot LibreELEC from the card, either.
Originally posted by dstojic View PostThanks for fast replay Magendanz. Maybe i´m offtopic- what about Libreelec from SD card. Is any way to start LE without reset button?
In a Android Terminal App type "reboot update" to get LibreELEC up and running.
Then in LibreELEC Kodi's - Power Menu - select "Reboot from Internal" to reboot into Android again.
Originally posted by wrxtasy View Post
With the freshly flashed LE on the SD card and the correct dtb.img also on the card.
There are currently 2100 users online. 0 members and 2100 guests.
