Guest
Originally posted by luckyzor View PostI don't want to go to stock rom because even 720p files was a nigthmare to run. just wondering why with this rom the first time plex was OK with 1080p files and now it's not. :/
There's some confusion about OEM firmware (what many refer to as "stock ROM") and my Nexus Stock variant (which is based on the Open GApps Stock variant).
The Plex problem could be due to changes made in the underlying OEM firmware from 20170715.093046.V0321 to 20170815.182813.V0321, or it could be a problem introduced by switching from regular Android to Android TV. Since I don't mess with the codecs or A/V policy, it's unlikely to be something that I introduced in the custom ROM.
Originally posted by Magendanz View Post
Sorry, you said earlier that it was working fine on the stock ROM. What do you mean "with this rom the first time plex was OK"? Are you saying that it was okay on M8S_PRO+-V0321_Stock-20170727?
In the Stock Rom nothing worked... when i installed via OTA this: M8S_PRO+-V0321_TVStock-20170825 plex worked with 1080p files. now I need to change to 720p or the image stops and the sound continues.
Just wondering if this box really has reset button inside AV hole.
I tried insert toothpick into the hole but it seems no button at all. Or did I break it already?
Anyway luckyzor I use Plex app too and there are no problem about playing 1080p video. (But on OSD player control the fast forward button doesn't work.)
#139.1Guest commented31 August 2017, 00:30Editing a commentThe reset button isn't where you'd expect it on this box, but it's there: http://freaktab.com/forum/tv-player-...688#post660688
Guest - I know you have disabled Bluetooth as the hardware doesn't support it but is there a way to manually add back Bluetooth support for a USB Bluetooth dongle?
I'm trying, but it's proving more difficult that I'd anticipated. At this point I'm waiting for hardware for testing, since I have no Bluetooth dongles. That said, I'm also trying to use this ROM on the Mini M8S II, which does have Bluetooth hardware and I'm still unable to fully enable the Bluetooth features in Android.
For more history on this, there's a discussion on this forum that starts here: http://freaktab.com/forum/tv-player-...11b-g-n/page23
To save you some effort, I've pre-packaged everything that longnt discusses here into one .img file:
So, I've just repackaged this system build with the U2+ Nougat kernel. I've added my latest TWRP recovery for p212 (using the U2+ recovery kernel) and eliminated the MAC keys that required licenses. Note that this system build hasn't yet been customized for p212. Specifically,
- Bluetooth is still disabled (because the M8S PRO+ doesn't have it)
- Key maps for remote controls need to be updated in the device tree
- Wireless drivers need to be updated
- Widevine L1 libs need to be swapped for L3 versions
All that will be forthcoming in a custom ROM for the p212, but this should give folks a head start if they want to live on the bleeding edge.
1.-install official rom U2 + version 2017-05-10
2.-install your package so that it can be compatible with mini m8s ii
3.-start without problems but I can not see netflix at 1080p
Install apk netflix atv error ui-800-3
Install apk netflix smartphone but only sd quality
sorry for reissue but I have to say that plex does not work to 1080p video with ac3 audio, black screen.
What was my mistake
thanks for your reply.
Originally posted by bajann View Post
how mecool works on tanix rom android 6???
Simply do NOT do it. You are going to permanently break DRM, like what you see in the previous post.
Guest
It's important to understand that none of the private keys in the TrustZone secure storage (Widevine keybox, HDCP license, Mac address, secure boot set, etc.) are stored in the .img file. While the names are in the device tree (DTB), the actual private keys are generated from separate DLLs placed in the /license folder of the USB Burning Tool. Simply flashing an .img file won't replace those keys unless you check the Overwrite Key option in Configuration. Don't ever do that!! These are set at the factory and are pretty much impossible to replace if you mess with them.
The takeaway here is that I can't build a custom ROM .img file to give your box Widevine L1, and you can only flash a ROM to take it away if you check Overwrite Key.
If someone at the factory gives you the license files (.ini files and DLL) for Widevine L1 or HDCP, you could potentially do it, but often these are hardware-specific and can't be transferred. And ultimately, no one is probably going to be willing to sacrifice their job just so you can play Netflix at 1080p.
Great Info M !
Originally posted by Magendanz View PostSimply flashing an .img file won't replace those keys unless you check the Overwrite Key option in Configuration. Don't ever do that!! These are set at the factory and are pretty much impossible to replace if you mess with them.Last edited by wrxtasy; 31 August 2017, 10:35.
Guest I found the problem. There are one option in Plex app that must be off. Now everything works great. Thanks alot for this rom hope it will be updated for some years. I have just one last question, how can I see if netflix is HD or not?
Please give me the instructions so I can donate something for your work.
@wrxtasy tks to you to about the libreElec dual booting
Glad to hear! The easiest way to check Netflix resolution is to run the test videos. A text search on "test video" will show them up, and they'll show the current resolution in the upper-right corner. You can also search the logcat for "getConfig OMX_IndexConfigCommonOutputCrop pRect->nWidth=1920, pRect->nHeight=1080".
As for donations, I always appreciate beer money! :-) My PayPal account is just chad(at)magendanz.com.
Originally posted by demasiado View Post
Please report which is the Plex app option that must be off. Thank you.
Play Smaller Videos at Original Quality - OFF ( before it was ON ) This was making my videos in 720p or less stop working (no video, only sound ) in original quality.
Now in OFF everything works great in Original Quality (tested in 3 different box's with same rom + same plex version )
Don't know if u have the same problem but this solved mine, hope I have helped
Magendanz, i was wondering if there is any auto update built into your custom rom (for the open GApps etc..) or is it possible to manually update to the latest versions?
Also can anyone recommend a compatible voice remote that works with this rom?
Bit of an AndroidTV noob here but really liking your Rom on my Mecool M8S Pro +
Finally got my box but I'm having some trouble burning the image file, I get the android image with a red cross on top. I'm using burn card maker (don't have the usb cables) and following the same process I've used to install custom roms on my GT1 and M8S II, what could I be doing wrong? Do I have to install anything before the .img?
There are currently 1648 users online. 0 members and 1648 guests.
