I went from stock 7.1.1 to atv rom. Cast does not work at all with youtube etc. Should i flash again. Thanks did update using ota local file
Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
#32.1Guest commented30 July 2017, 12:42Editing a commentWe've found that Google Cast only works in very rare cases, like when casting from YouTube in the Chrome browser. In all other scenarios, it seems to fail to get a valid Cast device cert through ClientAuthSigner. This has been a longstanding issue.
Originally posted by tillaz87 View Post
Could you try this video as its easy to notice in this because of fast movement
I believe its the second result when searching "60 fps video" in leanback youtube, its almost like a split second pause every so often
Make sure quality is set to 1080p 60 <-- as this is only where the problem is seen on my device
Guest
Originally posted by longnt View PostLike Magendanz said, there is incompatiable between p21x and p212 board, you must find Nougat build of p212 first. I already point to U2+ 905x firmware thread that make all p212 boards can run on Nougat build. After that you can mix bootloader, kernel, dtb from p212 boards with system from this p21x rom to make your p212 run Android TV 7.1.1 like me. If you want to know how to do, here is the guide:
So, I've just repackaged this system build with the U2+ Nougat kernel. I've added my latest TWRP recovery for p212 (using the U2+ recovery kernel) and eliminated the MAC keys that required licenses. Note that this system build hasn't yet been customized for p212. Specifically,
- Bluetooth is still disabled (because the M8S PRO+ doesn't have it)
- Key maps for remote controls need to be updated in the device tree
- Wireless drivers need to be updated
- Widevine L1 libs need to be swapped for L3 versions
All that will be forthcoming in a custom ROM for the p212, but this should give folks a head start if they want to live on the bleeding edge.Last edited by Guest; 01 August 2017, 02:58.
Guest
Which ROM? The one in the original post? Or the one in the post just above yours?
The ROM in the original POST is an OTA update, which you can install from the UPDATE app or TWRP. The one above is an Amlogic burn package (.img file), which will need to be flashed from a PC with Amlogic USB Burning Tool (with a USB male-to-male Type A cable) or Bootcardmaker. The second ROM needs to be a burn package because it needs to repartition the main eMMC storage.
Originally posted by Magendanz View PostWhich ROM? The one in the original post? Or the one in the post just above yours?
I was asking about the first one (OTA). I prefer this one since it is easier to install.
Thanks for the prompt reply and for your amazing work.
There are currently 1503 users online. 0 members and 1503 guests.
