Originally posted by Floki View Post
Ah ok I get it now, it's different, I'm in europe so there's no warehouse to choose from, only chinese available and there yes it's the cheapest it has been, I believe.
my Mecool unit worked fine for 1 week with ATV ROM but, now started locking up, even on boot, freezes often (not always) on splash screen or Android dots
tried reflashing with USB BurnTool 2.08 with either M8S_PRO+-NMF26Q-20170815.182813.V0321 or M8S_PRO+-V0321_TVStock-20170825 BUT, on power up keeps freezing
Burn Tool shows OK, no errors
am I doing something wrong ? what else can I do ? have I got a bad unit...?
Originally posted by Bllq21 View PostI just bought this box from Banggood really cheap 30.99$
I can't wait to have it in my hands and installing this ROM
using this rom my box did nothing but freeze and have problems... it's working ok now back on the 815 stock firmware
Originally posted by clsA View Post
you might want to read the last few pages and see most of us prefer the stock rom over this one and spent hours getting back to stock
Yes and now it's been added to the first post
I've read the whole thread but as I was still auditioning the modded ROM I wasn't too concerned about reverted back to stock but now since I've run into issues with it I'm considering putting it back to stock.
Originally posted by KBJ55 View Post
Yes, I thought so, thanks. I guess my question is about you saying you spent hours getting it back to stock. Was the before the stock ROM was posted or while using that image?
then flashing the file wasn't as easy as I thought, it actually took 4 tries for it to complete 100%
I ended up having to hook up the power adapter and the USB for it to complete
Hi! First I want to say thank you so much for your hard work!! Great ROM.
I have a small problem...just flashed my second box with this ROM. First box works fine. After flashing the second, it just feezes after some 5-10 seconds. Both when i boot to Android and Librelec on sd card. I wanted to try to reflash, but i can never make it to the menus before it freezes or restarts. Can anyone give me a hint what to do now? :/
There are currently 1937 users online. 1 members and 1936 guests.
