Originally posted by Gumbas View Post
Yes, got same problem also with original rom. Also apps are crashing, just before I switch on box I get pop up about for example "google play stop running" or any other app stop running.
A bad power supply can also cause lots of bad issues, but not sure how to test for that. From personal experience, I would 'assume" the power issue, is more of a problem than internal components on the board.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi Magendanz,
Current ATV ROM seems to be based on a 20170825 FW
Notes give latest available IMG as 20170815 FW
My latest box (with Freezes) has 20170829 FW installed
Gearbest just told me to install 20170715 .....
Is it possible to add all the available IMG and ZIP OEM Firmwares to your OneDrive p21x Folder for one handy access point ?
Or if you don't want to waste space in your account then can you post the links here or in Post 1 if possible.
Can't seem to find the 20170825 FW ! or my 20170829 FW
May not have looked hard enough of course ...
Thanks,
Pete
p.s. I have looked back but can't find it ... I think you posted a method to extract the box FW to a zip when you were trying to get the latest version and no IMG was available ?
Can you post a link to the method and any tools needed (or the post you made before) - Thanks.
Originally posted by emilb View Post
Here is how it is currently until I tidy it up a bit, it looks funny but since it's all out of sight I don't mind, and it stays without the top lid on
Thanks,
Pete
CPU-Z says 1.51GHz
Gearbest don't offer any installation instructions - I guess they expect one to use the Update APP !!
Specification
Brand: MECOOL Model: M8S Pro+
Type: TV Box
System: Android 7.1
Processor: S905X
CPU: Amlogic S905X
Core: 2.0GHz
GPU: Mali-450
RAM: 1G,2G
ROM: 16G,8G
Max. Extended Capacity: TF card up to 32GB (not included)
Originally posted by zappomax View PostGreat porting!
What about HDR 4k contents on Netflix? Has someone tried to see it with this box or is full-hd the max resolution?
And what about Amazon Prime video Android TV app? Does it work with this rom?
Chrome may work to allow Amazon 1080p streaming but IMHO that doesn't seem like an optimal solution for an ATV device. I'd say the Kodi Amazon add-on (1080p) option seems better although IIRC it requires Leia. Loaded the Amazon Video_4.1.115.apk from Shield TV and it installs and runs fine however like Xiaomi Mi Box it won't stream any video. So now I'm wondering would spoofing an Nvidia Shield TV, instead of a Nexus, allow the Amazon Video app for Android TV to stream on the M8S Pro+?
Guest
Originally posted by P.X View PostIs it possible to add all the available IMG and ZIP OEM Firmwares to your OneDrive p21x Folder for one handy access point ?
Or if you don't want to waste space in your account then can you post the links here or in Post 1 if possible..
Originally posted by P.X View PostI think you posted a method to extract the box FW to a zip when you were trying to get the latest version and no IMG was available? Can you post a link to the method and any tools needed (or the post you made before) - Thanks.
For Rockchip, there's this handy tool: https://forum.xda-developers.com/gen...mware-t2915363
However, I haven't yet found the equivalent for Amlogic devices.
Originally posted by Magendanz View Post
The easiest solution is to just do a backup in TWRP, but my preference is to do it manually using the dd command in Terminal (which requires root or you to be in TWRP's Terminal).
Guest
Originally posted by Magendanz View PostFor Rockchip, there's this handy tool: https://forum.xda-developers.com/gen...mware-t2915363
The only downside is that there doesn't seem to be an option for just dumping the entire partition, so you've got to know the sizes first. Ideally, we could revise this to pull the actual partition table from the device, then we could be confident that we'd gotten everything.
UPDATE: The docs for Amlogic's Update.exe command line tool are here: http://freaktab.org/dfca1cce86152d3cLast edited by Guest; 22 September 2017, 23:04.
@Magendanz - Any thoughts on whether spoofing a Shield TV might allow the Amazon Video app for Shield TV to stream on your ROM?
There are currently 2135 users online. 1 members and 2134 guests.
