I know that Cetus remote works OK but I need something smaller, simpler with mic over wifi.
Guys, do you know how to force to work Android TV Remote in the last ATV Rom ? I've read somewhere on this forum there are problems with this service (over wifi) but some older version of this service worked OK. Maybe there is way to solve this problem like it was with youtube (delete apk in root)??? Unfortunately I coudn't find this service in root to swap it with older one. Do you know any solution for that?
Hello everyone! I updated my mecool m8s pro+ for this rom because I was some problems with the netflix app. I was using the stock rom of Mecool m8s pro+ and one day to another the netflix app stop working, i tried to instal another versions of netflix app but all of them has the same problem, they stop when appear the name "Netflix", some versions stop in a black screen... I am use the apps Kodi, Youtube, mxplayer and anothers with no problems, yesterday I've tried to instal the app DRMInfo by playstore to see the Widelvine level but it don't open too. Someone know what problem I have and how can I solucted? Thanks!
Originally posted by luscas27 View PostHello everyone! I updated my mecool m8s pro+ for this rom because I was some problems with the netflix app. I was using the stock rom of Mecool m8s pro+ and one day to another the netflix app stop working, i tried to instal another versions of netflix app but all of them has the same problem, they stop when appear the name "Netflix", some versions stop in a black screen... I am use the apps Kodi, Youtube, mxplayer and anothers with no problems, yesterday I've tried to instal the app DRMInfo by playstore to see the Widelvine level but it don't open too. Someone know what problem I have and how can I solucted? Thanks!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Did you do a system reset?? Also, you need to install the Aptoid apk so you can side load other apps. Then download and install the DRMinfo app again.
No... I did the OTA uptdade but i din't found the reset button. I'll try later download the DRMinfo and post the result.
Originally posted by allandacruz89 View Post
Man I think he is taking about to wipe the ROM.. Go to recovery and do a wipe as you were install a new ROM, and reboot.. It will clean your ROM like a factory reset.. Not physical button to reset as you're thinking..
Originally posted by luscas27 View PostI do that when I was using the Stock rom, after instal nexus rom i didn't do that, but I can try this too.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The only reason was asking about your Widevine level is because Netflix installed from the Google play store will not work unless you have Widevine level 1. Your box came with level1, and perhaps you lost it somehow.
Originally posted by struthm8 View PostAfter power up I use the remote and move down to "apps" row. Then scroll back and forth across the 5 apps.
After about 3 time across and back, across and back, across and back, it shows on the screen that it is powering down and it shutsdown.
Changed to wireless remote and haven't had an issue since.
Originally posted by clarkss12 View PostI mean to go into Android settings and do the reset.
I tried this one more time but didn't work it. The netflix app and the DRM Info doesn't open (Even the another versions)... I don't know what can I do, netflix is one of the reasons that I buyed this box.
http://blog.geekbuying.com/2017/12/m...date-20171220/
Of course you have read this from the first post......
WARNING: There's a bad batch of M8S Pro+ boxes which are experiencing regular freezing and crashes. We've narrowed the source of the problem down to a Samsung eMMC 5.1 chipset (KLMAG1JENB - B041), batches SEC 652 to 713, and these usually shipped from the factory with version 20170829.121614.V0321 of the OEM firmware. If you have one of these, it's highly recommended that you not flash any ROM (custom or OEM), as the prolonged block writes seem to result in serious data corruption.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have forgotten what you have tried so far.. Did you already do a complete install using the USB burning method???
There are currently 1741 users online. 1 members and 1740 guests.
