Originally posted by P.X View PostThis is working on my L box - Way to get Amazon Prime working via Kodi 18 - hopefully works on Pro +
Need to use Wi-Fi to avoid buffering, but great to have a solution that works in at least 720P HD - Setting max 720 (default setting in my install) seems best for me as it then hits 720 rather than falling back lower if it tries to hit 1080 - probably my slow Broadband !
Thx go to mymo
Search works well but i can't have access to my favorites. (maybe a timeout of some sort, didn't manage to find the logs)
Originally posted by lezioul View Post
Do you experience trouble during the naviagtion process?
Have to use search, or find in one of the lists (though not all populate ??)
Just got this TV Box today and it seems to have a newer firmware: 20171208.183013.v0928.
Can I install the latest version of this ROM if I have the newer firmware?
Hello,
First of all, forgive my english it's a translation.
I ask you because I flashed my mecool M8S pro + with another firmware (Mini.M8SII-SCV1A-ATV). I did not know that there was a fix for wifi and I wanted to make a wipe with the twrp that installs this rom.
Woe to me, I thought I could start the month on twrp but I feel that there is more recovery. I start the machine with a pressure on the recovery pin but it has no action (even with a SD card filled with a rom).
I am stuck on this image that loads from the beginning.
Is there a way to unbrick this box? Gennre a Nand Chip Short?
(I specify that I tried this rom that works on a box Tap ((905x too)) compared to the application mycanal which posed problem).
Originally posted by SergioKool View Posti still have random wifi drops on this box or rom all my devices that i have none do that all stable wifis except this box or rom, anyone know or already fix this or know how to fix this to be stable? or have some other rom with stable wifi?
Originally posted by uscool View Post
WIFI is stable for me using ROM from here speedest gives around 33-40mb . maybe try to change wifi channels on router ?
i dont say speed cause i have good speeds around that numbers, but the wifi at random times keep turn off and on and sometimes turn off like a minute and tunr on itself again automatically and its not from router cause all my devices are stable and never give me that kind of wifi turn off or drops and i have a old android box before with android 4.4 and never give me this kind of wifi drops :S and i read on the internet and im not the only one to have this kind of problem :/
There are currently 3899 users online. 0 members and 3899 guests.
