Thank you for pointing the tool out. Installed and tried the tool. It does something, but not the way I'm used to.
It changes the screen from 60hz to 24hz, but when I stop the movie and when it goes back to the menu it remains 24hz.
It won't revert back to the 60hz making the Kodi menu appear sluggish / lagging.
Also it selects the wrong hz sometimes, for example if I choose a 24 frame movie it stays on 25hz if the previous movie was 25 frames.
This together with the fact that you have to turn the option on every time you reboot makes it far from the pleasant user experience I'm used to with my old Minix system.
After months using the Nano version (on a box from the bad batch) I decided to use this version and it works great
But I installed an app (Claro Video) that app doesn't works on rooted devices so when I was on Nano Rom I used Xposed to use it
and it worked perfect but now on this rom it crashes.
I installed Magisk to hide root and it works for other apps but this one doesn't even open
What can I do?
What might be the reason it's there any way to know why it crashes?
Hello Magendanz, I just installed this M8S Pro+ box. It installed just fine. However, it does not do chromecast which was the primary reason I wanted to install this. Do you know how I can activate it? I tried from a Android Tablet. It can see the box, but when I press Chromecast button, it just circles and then eventually dies. Is there something I need to do to activate?
Also, the device does not seem to be rooted. Can you provide instructions on how to root this?
Thanks. Then why are folks installing this ROM? When there is already 7.1.2 ROM available. I will revert to OEM ROM. My only interest was due to Chromecast capabilities.
This is working on my L box - Way to get Amazon Prime working via Kodi 18 - hopefully works on Pro +
Need to use Wi-Fi to avoid buffering, but great to have a solution that works in at least 720P HD - Setting max 720 (default setting in my install) seems best for me as it then hits 720 rather than falling back lower if it tries to hit 1080 - probably my slow Broadband !
I found a way to watch Amazon prime contents on this device.
It can't be done through the Amazon app as we all know now, if nothing has changed since the last time I tried, but it can be done through Kodi. All you need is
Once finished installing, open the Amazon video or Amazon Vod addon (depending on the country you live in), and configure it by entering your email, password and the secret code that will be sent to your email account. Then it will automatically install some add-ons upon which it depends and ask you to enable Inputstream. Don't forget to select "playback with Input stream" during the configuration.
There can be still issues with the subtitles, otherwise the add-on works like a charm... I tried HD stream so far, I haven't tried full HD yet.
My tv box restarts only often shortly after turning it on. After restarting I have to turn it off and on again because the wifi disappears. It happens to someone else? Is there any solution?
Did you manage to fix this somehow?
I've found similar issue after update to latest atv from stock FW
Wifi disables and box restarts after few minutes.
SEC is higher than 713 which should be fine.
Got several audio delay problem with this Rom on my M8S Pro+, with Netflix or french tv streaming app.
Anyone? or should I try to install again the all package... ?
