Originally posted by fpmpaolo View Post
If so, I will not upgrade by now. I'll wait for a stable version then.
in update ota which "wipe” to select?
I've just upgraded my M8S Pro+ (Stock ROM 20171208.183013.V0928, Chip: Samsung 628 KLMAG2GEAC-B031) to latest ATV and it work OK. I didn't notice any problem with youtube yet. But I'd like to ask about something - how can I add app to home screen. Some of the installed apps are automaticly added to "app line" and some of them not. For example when I've installed HBO GO it has been added automacicly (but didn't work in my region), so I installed HBO GO EU version which works OK but I can find this app only in "app draws". Is there any simple way how to add such app to homescreen ? I've noticed also that "option" button on the remote doesn't work so I can't use it like it was in the stock version.
PS after 20 min first Youtube crachLast edited by suarez23; 11 July 2018, 13:13.
Originally posted by harckan View PostHi everone, allandacruz89, gekeer, pdjm
I solved the problem with YouTube, version stock new ROM 2.02.14 is the problem.
1. Remove YouTube stock. I remove with ES File Explorer in root options.
2. Reboot
3. Install apk YouTube TV version 2.02.08 link above.
4. Run fine
ps. disable automatic update in google play store
leave feedback
suarez23 , I have Mecool M8S Pro + with Bad Batch Samsung, I clean installed this new Build and run fine in this time, better than the previous build, no crash or reboot.Last edited by suarez23; 11 July 2018, 14:58.
Originally posted by mjedi7 View PostAbout the YouTube issue, i can confirm that the problem lies with the version of the app from June 18.
If you are on 20171216, uninstall that version from Google Play Store the stock version works fine, and in the options, disable “automatic app updates”.
If you are on the new one, 20180706, you can use the method and APK posted by @Harckan. I recommend downgrade to 20171216.
In my case I upgraded to 20180706, Netflix also stop working, that’s the reason I went back to the old build. Very weird situation.
Good luck.
Originally posted by suarez23 View PostI've just upgraded my M8S Pro+ (Stock ROM 20171208.183013.V0928, Chip: Samsung 628 KLMAG2GEAC-B031) to latest ATV and it work OK. I didn't notice any problem with youtube yet. But I'd like to ask about something - how can I add app to home screen. Some of the installed apps are automaticly added to "app line" and some of them not. For example when I've installed HBO GO it has been added automacicly (but didn't work in my region), so I installed HBO GO EU version which works OK but I can find this app only in "app draws". Is there any simple way how to add such app to homescreen ? I've noticed also that "option" button on the remote doesn't work so I can't use it like it was in the stock version.
https://apkpure.com/tv-app-repo/news...repo.playstoreMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Use a third party "store" like Aptoid, and download and install "TV APP Repo", that will create a linked thumbnail on your main page. Or use your Chrome browser on your Android box and go to this link.
Thanks mate. I got one more question. How to get "power off" button on the home page. I've seen on the screens on this forum there is one next to "app draws" but I don't have it. Is there any way to get that button in the newest ATV rom ?:
What is wrong with the On/Off button on your remote?? In settings, you can change what that button does. Also, if you **depress** that button and hold it, it should give you a selection on what to do.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Using the same Aptoid **store**, search for "reboot". Pick one and install it. Use the "TV APP Repo" to create a link to your home page.
I've already added some shortcuts with the "TV APP Repo" and I must say it works great but the "power" icon from the screens on this forum look like it was integrated part of ATV. It is not added to apps line or games but at the bottom of the page. I'm not an expert and I'm just curious if there is a way to activate it, that it look like on the screens. Maybe that button was part of previous ATV rom and it is not avaliable in the newest one???
2. Reboot
4. Run fine
leave feedback
Hello knowledgeable M8S Pro+ people.
Thankyou very much for the time and knowledge you all put into this device.
I have resurrected my M8S Pro+ from the cupboard and upgraded to the 20171208.183013.V0928
I have checked the Samsung eMMC chip and it says Samsung 646 KLMAG2WEPD-B031. Since that does not match the eMMC mentioned in post #1 I thought I was OK.
I have a problem that the device powers off during basic use soon after startup.
After power up I use the remote and move down to "apps" row. Then scroll back and forth across the 5 apps.
After about 3 time across and back, across and back, across and back, it shows on the screen that it is powering down and it shutsdown.
I have done a wipe with TWRP just to make sure. So it is now clean with no other APK's installed.
I have left the lid of case off for ventilation to heatsink. It does not feel hot to touch when the issue occurs.
Any help would be greatly appreciated.
There are currently 4236 users online. 0 members and 4236 guests.
