I was having an UI-103 error but it had to do with a Magisk module
If any of you have problems with Youtube, I recommend playing this application https://smartyoutubetv.github.io/Last edited by Ewojtas; 10 August 2018, 16:33.
Originally posted by Ewojtas View PostIf any of you have problems with Youtube, I recommend playing this application https://smartyoutubetv.github.io/
That app looks shady to me
I just updated to the latest version of the ROM and everything works fine but when I turn off the box it freezes for a couple of seconds and then it shut downs.
It this normal or it is any way to fix it?
and I read you now can use IR remotes con USB dongles to turn on the box but mine doesn't work
Originally posted by Bllq21 View Post
Every comment on that page it's in Russian
you want to install it, you're afraid of it, do not install it. I have it on TV with Android and TV Boxei I'm more than happy. I just wanted to share with others what I found on the web. https://github.com/yuliskov/SmartYouTubeTV/releases/
Works well with the remote.
Does it block Youtube video ads?
I want a YouTube app that blocks YouTube ads.
[QUOTE = NewbBoxie; n739718]
Zainstalowałem go i wygląda na to, że jest OK.
Działa dobrze z pilotem.
Czy blokuje reklamy wideo Youtube?
Chcę aplikacji YouTube, która blokuje reklamy YouTube. [/ QUOTE]
Read the comments https://github.com/yuliskov/SmartYouTubeTV/issues/105Last edited by Ewojtas; 11 August 2018, 10:05. Reason: https://github.com/yuliskov/SmartYouTubeTV/issues/105 Read the comments
I haven't seen any yet.
I just didn't see it blocking ads as a feature of the program in its features list.
Originally posted by NewbBoxie View Post
So SmartYouTubeTV already blocks YouTube ads?
I never have to go through such a mess. I moved to android 4 years ago, and when I first heard peeps mentioning about ads in YouTube I thought they were joking. Just like the video a person placed as a link, stating he saw ads. It was funny as the product placement had been placed on the cans used in the demonstration.
Don't know how peeps get ads, never got one to see for myself. Though I don't cruise channels, just search for info.
I have been testing YouTube TV, and it has broad cast ads, which are impossible to remove without a go between server to catch ad streams and drop them. I use to do that with a proxy to identify all connections. Once I blocked pass through connection, blocked ads would not break connection, and play on with the programme.
I even blocked the player's media control function that was server based, for the difficult to remove ads. Won't allow skipping or pause, but will play from beginning to end continuously.
basically it was simple once I collected all the host names in background connections for ad services. Made that into a hosts file, which is the base for host ip resolving and blocking.
Works in all apps... needs a wee tweaking, but 10 of the 15 streaming apps have no ads. NBC apps are heavily hooked into Google ad services. Break an ad, you break the app or connection. You must hack the apk file to jump out of error checks.
There are currently 2031 users online. 1 members and 2030 guests.
