Hi, I have question for Polish Mecool users. Did Ipla apk (TV live channels) stop working for you last week? I know it uses DRM and the problem appeard at the same time as Netflix problem.
Interesting is that with the last problem (about 3 months ago) with Netflix related to DRM, Ipla apk worked OK. So, is there any way to force to work live channels on Ipla apk with fake Android TV ROM?
Originally posted by suarez23 View PostHi, I have question for Polish Mecool users. Did Ipla apk (TV live channels) stop working for you last week? I know it uses DRM and the problem appeard at the same time as Netflix problem.
Originally posted by tantrums View Post
Me too. I got error since yesterday.
hopefully Guest will update this rom using the new image.
Guest
That would be great, if you'd prepare an update for us! Thank you in advance!
@all
A question into the round: My Android video setting is 4K 30fps (due to the audio receiver limitation here). Does 4K Youtube playback work for you well?! Any video I start is running only few seconds and it's hanging then. Only killing the app helps.
Try this one: http://freaktab.org/bab6c9124f5b63a0
Same OEM images, but an update script that actually checks the build.prop on the system partition rather than the recovery partition. It will also allow you to downgrade.
@all
Originally posted by cph666 View PostAnyone using Plex on this box with this ROM? I'm facing (network?!) issues during starting / playback of movies from remote server.
The box is connected via LAN and also the internet connection is fast (50 MBit) and nearly not used, but Plex reports connection issues and stops playback.
cheers
There are currently 2815 users online. 0 members and 2815 guests.
