Originally posted by Marcelo Filgueira View PostHi, I have a M8S PRO +, I tried to install the rom and I had problems, after searching I saw that it has the S905W and not the S905X, does anyone have the firmware for the M8S PRO + with S905W?
sorry for my english, i'm using google to translate.
Hello. I have the bad batch box with Sec 701 emmc. The issue I'm having is that not in Firefox note in Chrome I can hear sound, but there is no video. First boot after flashing everything works fine, but after reboot video stops working. I use 2017.08.29 FW, cannot use any other. Have someone encountered such an issue and knows how to tackle it?
I have the Open GApps (20171216) currently installed.
I have searched for updates, but no updates are found.
However, I can see that the latest build of Open GApps is now Open GApps (20180706).
What is the easiest way for me to update my Open GApps (20171216) -> Open GApps (20180706)
I hope I can just use the OTA update and not tick the overwrite/data wipe option and this will just the update easily and quickly.
Please do let me know.
Thanks in advance.
I've updated to 20180706 using the built in update tool.
Now I'm having an issue with the Netflix app. Well at least the app starts after using burn tool 1.03. Before using the tool I uninstalled the Netflix app.
As mentioned the app starts nicely and also gives upstart sound. Scrolling at the dashboard within Netflix some titles also have sound. The first time I used the app everything was working properly.
But suddenly when playing any title I can't get any sound.
I've uninstalled and re-installed without any success solving the issue.
Anyone who have experienced this?
Or have a suggestion to solution?
Originally posted by eramik View PostBut suddenly when playing any title I can't get any sound.
If you do, change this to Auto instead and restart the player.
Then go into Netflix and try playing something.
Please let me know if this helps.
Thanks.
Originally posted by Veloglou View Post
Originally posted by NewbBoxie View Post
Well, go into your Android Sound Setting and check if you have Surround Sound selected.
Thanks.
Resetting to factory settings didn't help either. Now I reflashed which partly helped as stero sound works, but not surround sound.
There are currently 2473 users online. 3 members and 2470 guests.
