Originally posted by theodor View Post
Originally posted by areq1987 View Post
No it's not related to w1 key... Ive installed it already.. I have another problem Netflix vidov start loading to about 70-90% and it gives error I describe. I have no problem with it on stock and previous version of this rom. So please kindly give me link to previous version of this rom. Thanks.
Guest Is it possible to fix it? The New build is Very much stable in my box, but no surround sound.
areq1987
try turning off surround sound in settings -> sound
Sorround Sound: Never
Digital Sound: PCM
I have and run the previous build for this problem, but I can not upload. Sorry
Good luck
Hi fellows.
Does anyone know how to hide root status on this tvstock version ??
I tried method with 7 times knock on build number to get developer options, but in developer options there is no option to turn off rooted status.
I need this cause i have some apk that refuse to work with rooted box.
Originally posted by vondutch View PostJust received the email with the fix for the PRO+
New burn Key Tool:
https://mega.nz/#!u49DwYxL!8VGKmEqCY...NyA72EAC_Cq3Fg
Originally posted by draxd View Post
OMFG they actually release Widevine L1 keys to someone. Google is so going to kill them. Btw Mecool release Android 8 TV box (MECOOL KM8) with similar specs to ours. Anyone is planning to port it ?
Hi all,
I just updated my mecool m8s pro+ to latest ROM version (M8S_PRO+-ota-20171208.183013.V0928.zip) with usb burning tool, and then used burnkey 1.0.3 to get Netflix working again. Unfortunately, Netflix still doesn't work ! More, when i check DRM info it shows HDCP : unprotected , looks like this is the reason why
After googling the issue, I tried the following without success : get back to the stock mecool rom, use HDMI splitter, use new hdmi cable, use analog converter, conncet to another tv.
Do you have any idea what I have done wrong ? Do you think it is definitively broken ? Do you have any suggestion to get Netflix working back (other than changing for fire tv stick) ?
Great forum by the way!
There are currently 2544 users online. 0 members and 2544 guests.
