Guest
Changelog (20180706):- Updated to latest M8S Pro+ OEM firmware (20171208.183013.V0928)
- Updated to TWRP Recovery 3.2.2-0 using latest OEM kernel
- By popular demand, included OEM Miracast app
- Latest build from Open GApps (20180706)
- Wake from sleep will result in a restart. This seems to be a bug in the underlying OEM firmware.
- Google Cast service broadcasts and is discoverable from mobile devices, but quits unexpectedly unless connected through Chrome.
- TVStock Variant: BURN PACKAGE (996MB IMG file), OTA UPDATE (532MB ZIP file)
Originally posted by Magendanz View PostChangelog (20180706):[*]TVStock Variant: BURN PACKAGE (996MB IMG file), OTA UPDATE (532MB ZIP file)[/LIST]
I'm running your AndroidTV Nexus ROM from 20171216
How do I install this new one?
Will I loose my settings?
Can someone confirm NetFlix is working?
Originally posted by harckan View PostHi,
I install ota update of new build, YouTube stop player and crash app after few minutes to play.
Thanks for your time and work
@Magendanz
Best regards
Can anyone confirm that M8S Pro+ (Stock ROM 20171208.183013.V0928, Chip: Samsung 628 KLMAG2GEAC-B031) works stable with the latest ATV rom? I have to say that it works very well with stock firmware unfortunalely the UI is a joke. I'd like to use ATV rom, especially it is based on this rom. Any experience ?
Originally posted by suarez23 View PostCan anyone confirm that M8S Pro+ (Stock ROM 20171208.183013.V0928, Chip: Samsung 628 KLMAG2GEAC-B031) works stable with the latest ATV rom? I have to say that it works very well with stock firmware unfortunalely the UI is a joke. I'd like to use ATV rom, especially it is based on this rom. Any experience ?
I have this same memory chip, everything else works ok.
Hi everone, allandacruz89, gekeer, pdjm
I solved the problem with YouTube, version stock new ROM 2.02.14 is the problem.
1. Remove YouTube stock. I remove with ES File Explorer in root options.
2. Reboot
3. Install apk YouTube TV version 2.02.08 link above.
4. Run fine
ps. disable automatic update in google play store
leave feedback
suarez23 , I have Mecool M8S Pro + with Bad Batch Samsung, I clean installed this new Build and run fine in this time, better than the previous build, no crash or reboot.
About the YouTube issue, i can confirm that the problem lies with the version of the app from June 18.
If you are on 20171216, uninstall that version from Google Play Store the stock version works fine, and in the options, disable “automatic app updates”.
If you are on the new one, 20180706, you can use the method and APK posted by @Harckan. I recommend downgrade to 20171216.
In my case I upgraded to 20180706, Netflix also stop working, that’s the reason I went back to the old build. Very weird situation.
Good luck.
There are currently 1894 users online. 2 members and 1892 guests.
