i found older versions there,
Originally posted by kodiwpigulce_pl View Post
Look at photo. -> https://image.prntscr.com/image/9WnW...PehatAEu0g.png
It looks like we have the same box ( build 20170815.182813.V0321 - SEC649 B041 KLMAG1JENB S54T3MGMS)
You said you installed latest ATV (20171001)... is it running stable for you? Have you come across any issues?
I would like to use it mainly for Youtube and Kodi.
Originally posted by legnosecco View Post
Thank you for replying.
Guest I have a box from a bad batch with the 5.1 emmc, I just runned LE the first days scared that flashing your ROM could break the box, after seeing the guy that short the pins I just tried you ROM using the OTA method, everything went smoothly and I have it working now, am i good to flash it by USB Burning Tool ?
No.
You need to remove the 4 rubber feet on underside of box...and then remove the 4 tiny screws and the cover lifts off...it's not difficult.
It shipped with 20170815.182813.V0321
I tried to use the updater and it doesnt see any updates to the firmware.
Is it even safe to flash the 20170918? I checked the updater on the device and it says no firmware found.
Originally posted by numus View Post
Yup I have the damn B041 713.... I just bought this thing for 50 bucks on amazon
Is it even safe to flash the 20170918? I checked the updater on the device and it says no firmware found.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
My M8S+ PRO has .....SEC649 B041 - KLMAG1JENB S54T3MGMS - build 20170815.182813.V0321
Based on @ kodiwpigulce_pl who reported success installing the latest ATV 20171001, I decided to to give it a go.
I placed the ATV zip file on a USB stick and then installed it via the OTA app and selecting "Wipe Data" option
It installed the update first...then rebooted with the NEXUS logo...and after a few minutes was all done...all thanks to @Magendanz
So, it looks like the above chipset maybe good to go with ATV.
EDIT:
I have been playing around with ATV for a couple of hours...first impression not very user friendly.
Is there a way to disable the mic icon as I don't have one to use "speech"
How do you add/remove apps from the Apps line on the Home screen?
I don't like the Youtube app 2.01.4 (system installed) and I can't uninstall it...I much prefer the nicer looking older Youtube app 1.3.8 where I can select video quality as well...but it won't let me install it !!
On the plus side, I have switched on/off several times and the ATV seems fairly stable.
So..
I received my box. The rom is 20170829... I opened it... and (no) "surprise": Samsung KLMAG1JENB - B041, batches SEC 713.
I followed the advice of wrxtasy , return to sender, and refund !
I will look elsewhere.
Thanks!
S805 MK808B-plus (alive & rocks on LE), S905X T95X (on U2+ mod rom ATV 7.1) and maybe later a S905x M8S Pro+...
Originally posted by Kazan View Post
If you have bought from Amazon directly and not from 3rd party.
The Amazon return policy in UK is here, but for bucks you probably need the USA equivalent, the important thing is to get the claim started witin 30 days:- https://www.amazon.co.uk/gp/orc/retu...rl_ret_hp?fg=1
I bought mine direct from China at $25
Originally posted by Jeffers View PostI bought mine direct from China at $25
It can be interesting to know where to buy and where NOT to buy.
If we can determinate from which seller we can have a good box, orders could be more safe !
Originally posted by StarDreamer View Post
Can you tell us the seller of you box, and date of order ?
There are currently 2000 users online. 1 members and 1999 guests.
