    Originally posted by anthonytex View Post
    Hello, i want to say a big thank you to Guest My box is just arrived. Seems to be the last "stock" without reset button and last firmware.. Everything works good thanks for this ROM
    hi there, where did u order the box and when?
      Hi, gearbest on 26/09/2017
        i got one with SEC649, but also with KLMAG1JENB - B041. Is this one risky too?
          I have the same one.
          But what is your build?
          see my post #968
            Same as your, build 20170815.182813.V0321.
            So I assume that this is ok ?
              Personally, I would try an OEM Update to the first release FW using Update app before anything else, just in case, as this shouldn't affect the warranty !
                Flashed this awesome ATV firmware yesterday on my newly received M8S Pro+ 2G/16G from official firmware dated 19-09 and it's working great
                Process used: Rebooted in to recovery using Reboot app (as this box doesn't have the reset pin so couldn't use the burn tool ) installed the update zip, cleared cache and data and rebooted.
                Many thanks Guest!!!
                  I would say your ok...but there are always risks when flashing any device...and I decided to take that risk.
                    Yes, but i know now that this one is acceptable risk
                    Thank you mate.
                    I got another one with sec 652 and 20170829.121614.V0321. In first post of this theme they write that bad batches are from 652 to713, and here...
                    in first post they write that bad batches are only from 701-713. So what to do with this ?
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      I updated that a few weeks ago to include SEC 652.
                    I say #1019 again
                    0829 is a warning ...
                    The Thread Warnings should both be the same so I would take it that 652 is added to the warn list !
                      Thank you mate.
                      Based on first hand experience (see earlier posts), SEC 652 boxes with the 20170829 firmware are a no-go for any other firmwares.
                        Damn it. I supposed you purchased it from Bangood also ? Any tips for refund, did they accepted cause rhis bad batches are not suitable for normal Official OTA Update?
                          hi ,
                          i have sec 728 boxes with 20170919.150557.V0619 build from G**rbest , is it safe to install this ROM?
                            Received my box from gearbest this morning with KLMAG1JENB - B041 SEC 728, and firmware version 20170919.150557.V0619. I flashed it with this rom without any problem.
                            thanks Magendanz
                              To be honest, haven't approached them. Still playing with the box at this point.
