Hi Guest , can you tell me how to pull an APK from the Android TV version ? I have tried to connect it to my computer with the Male to Male USB Cable and later use ADB Pull, but the terminal does not recognizes it.
I have used on linux the command "lsusb" and see if i can create the 51.android rules, but nothing shows. I tried on Windows, but the command ADB Devices does not see it.
The APK is one for the latinamerica market, you can not download it from the PlayStore cause it always download the mobile version of the APK, not the Android TV version, it needs to be pulled from the device
Can you help me plz ?
Originally posted by Rubytux View PostHi Guest , can you tell me how to pull an APK from the Android TV version ? I have tried to connect it to my computer with the Male to Male USB Cable and later use ADB Pull, but the terminal does not recognizes it.
Hello,
I had one of the bad batch and tried to get another one. So now I got one with the kingston memory. I could flash everything but wanted to try the atv rom. To do this I wiped everything in TWRP (stupid, I know) and now I can't get into TWRP or something else. The only thing I see is the NEXUS boot screen and after a few minutes the device is shutting down.
I don't have a reset switch and tried the Nand Mask ROM flash method but nothing happens if I shorten the pins. Now I'm not able to flash some image with the sd card method or the usb burning method. Is there no possibility to let my computer recognize the m8 pro+?
Originally posted by cmfp80 View PostGood afternoon, I installed libreelec on a USB stick and I have dual boot, however with libreelec the remote box control does not work. Does anyone know of a solution for the remote control to work? Best Regards
Originally posted by demasiado View Post
Hi, have you added all wrxtasy's files (http://wrxtasy.libreelec.tv/MECOOL/), including remote.conf ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Magendanz commented
11-10-2017, 11:36
Ouch! The Mask ROM reset should only be used as a last resort. If you can boot to TWRP, you can recover and you can always flash using the burn package with USB Burning Tool.
If you don't have a male-to-male Type A USB cable, you can remove the environment checks from updater-script.
All in all I'm pretty sure it was a driver issue. But my old (bad batch) one was recognized by windows 10. I really don't know...
There are currently 2314 users online. 0 members and 2314 guests.
