#211.1Guest commented05 September 2017, 19:27Editing a commentI'm still trying to get Bluetooth working on the p212 boxes. The plan was to use the M8S Pro+ system image, but apparently there are precompiler directives that need to change and just adding the needed files won't do it. Without source, that's now a dead end.
My current effort is to adapt a S912 ROM for S905X, which requires downgrading Mali-T820MP3 to Mali-450MP. Still working on that.
Originally posted by jack1142 View PostHi,
I have a question about that ROM before I buy Mecool M8S Pro+
Will this remote (https://www.geekbuying.com/item/MX3-...es-319093.html) and its microphone work with that ROM?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by jack1142 View PostI have one (w/o mic unfortunately :/) and I don't know, what you mean. Maybe it would be better, if it would be mat, but it's not such a big deal. Thanks for answer thoughI can buy it now.
Originally posted by jack1142 View PostI'm not sure, what "flaky" means :/
I'll ask simply to be sure. Do remote and mic have full functionality?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by filiperuivo View Post
Follow this steps to connect the box to the pc
1- Install the USB Burning tool and make sure the drivers are also installed.
2- Because you have a few seconds to make this work, plug one end of the usb cable to the pc, and the other one, gently place (point) to the usb port in the box, but don´t plug in all the away.
3- Press and hold the reset button and insert the power jack, as soon the light change from red to blue, quickly plug the usb and release the reset button, should be easy because you already pointed.
I also find it difficult to connect my box, and this away works every time for me.
I hope it helps.
Magendanz commented
09-04-2017, 05:
Yes, there's no need to connect the power cord. USB OTG will provide enough power. Just ensure the reset button is depressed when you connect the USB OTG cable.
Tried just the OTG cable but no power LEDs !
Found that this sequence seemed to work for me to get connection
Start USB Burn Tool
Click Second Top-Bar Menu Item > English
Connect OTG (Rear USB)
Press-Hold Rest Button
Insert Power - Wait 8-sec - Connects (HUB9-4)
Release Reset Button (Blue LED on Box - NEXUS Splash Screen)pp
But having issue with Flashing - Keep getting ERROR code(s)
Not sure which Options should be Selected (Except NO Overwrite Key !)
Attached Screen Grabs
Pete
UPDATE:
Person with little knowledge = Dangerous !!!
I removed the OTG and tried to re-Boot to Recovery ? TWRP
Got to the Standard Recovery Screen and it started reading from the USB/SD card (I put it in ready to Use TWRP but didn't get that screen)
Recovery started an Update and erased some stuff ?
Then got loads of Read Only Errors generated from SD Card ... Forgot keeps seeing SD as Read Only
Returned to Recovery Options Menu.
I decided to install from USB - Inserted real USB Flash Drive and chose the ATV zip I had already on the USB (version 1)
This Flashed and a quick Re-boot and now have a clean ATV Install
I think I got lucky
PeteYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by P.X; 06 September 2017, 17:12.
I can't get away from this rom... When I flashed this rom via the OTA app from the orginal firmware, I also erased Media in the OTA app.
So I just flashed the stock rom from this thread, but i'm still missing the OTA app, witch probably is because I chosed to erase media.
The thing is, The official rom is only released as a zip file, not a IMG, so I can't flash it with USB burning tool....
is there anything else i can do to get back to the official stock rom?
Originally posted by Macen View PostI can't get away from this rom... When I flashed this rom via the OTA app from the orginal firmware, I also erased Media in the OTA app.
how did you get stock recovery and still be on this rom ?
If you still have TWRP use M8S_PRO+-20170715.093046.V0321-signed.zip
after you flash it flash TWRP.img and Magisk.13.3 before you reboot
Guest
The latest OEM firmware is available as an Amlogic burn package (.img file) here: https://mega.nz/#!rEU1SSBS!EGUpAkti-...Eia2Er0AxuuH5g
Originally posted by Magendanz View PostThe latest OEM firmware is available as an Amlogic burn package (.img file) here: https://mega.nz/#!rEU1SSBS!EGUpAkti-...Eia2Er0AxuuH5g
is there any possible way to fix that? its like its some sort of permission issue somehow
What version of netflix is working on ATV ?
Normal version or ATV version (who need DRM L1)
Big promo on banggod 29,99$
https://www.banggood.com/MECOOL-M8S-...p-1175123.html
There are currently 1346 users online. 2 members and 1344 guests.
