thanks a lot for the suggestions! I actually did try CentusPlay before, and am also using it as an alternative remote as in some games the Android TV Remote is not working properly.
Anyways in regards to Chromecast:
I was not 100% clear in the description what I wanted to achieve.
What I wanted to achieve is to tell my google assistant on my phone to play some music on my tv.
As simple as this if everything works with Chromecast built in..which does not work
But I have a solution!
I am using Tasker/autoremote/autoinput on my phone and on the TV box and now I can tell my google assistant to start my radio on my tv, and it actually works .
It I a bit more work to set it up correctly, but worth the effort
I can even talk to the Android TV remote and it will work directly on the TV box. Just had to sideload the google assistant...I did not yet integrate tasker with google assistant on the TV box as I am currently having a small issue with google assistant on the box:
As soon as I open the app, not via the mic which works fine, it asks me to update the google app. t opens the playstore and points me to the app. Unfortunately I cannot install it, also not via sideload as it is not for TV. And google assistant does not recognize that google for TV is installed...another small hiccup
Anyone an idea?
Also if wanted, I can describe a bit more how I did setup the tasker configuration mentioned above.
Cheers,
Bornello
